| What we should to do to run an application? [message #170421] |
Thu, 01 June 2006 18:10 |
Originally posted by: frankpeng.netscape.net
Hi, Every body!
I have a web application runnig at www.ddint.org. I want to do some
modification so I want to load it into Eclipse.
I created 2 projects. Added all libraries and src into its directory. I
added the first project included to the second project. I imported the
srcweb into the second project's WebContent.
Now everything is OK except 100 warning.
I did not do anything about the listeners. I do not know how to do with
it. I think since the code and JSP files are all compiled there should not
have problems. Now I right-click on the second project and choose run on
Server,..
I have set up runtime and server runtimes, it worked with other project.
It should not have problems. Some one please help me with listeners.
I got the following message:
Jun 1, 2006 5:21:07 PM org.apache.catalina.core.StandardContext
listenerStart
SEVERE: Exception sending context initialized event to listener instance
of class com.mvnforum.MVNForumContextListener
java.lang.NoClassDefFoundError: net/myvietnam/mvncore/util/FileUtil
com.mvnforum.MVNForumContextListener.contextInitialized(MVNF orumContextListener.java:81)
org.apache.catalina.core.StandardContext.listenerStart(Stand ardContext.java:3729)
org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4187)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1013)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:718)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:442)
org.apache.catalina.core.StandardService.start(StandardServi ce.java:450)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:709)
at org.apache.catalina.startup.Catalina.start(Catalina.java:551 )
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 94)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:43 2)
Jun 1, 2006 5:21:07 PM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context [/mvnforum] startup failed due to previous errors
Jun 1, 2006 5:21:08 PM org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-80
INFO: Starting Coyote HTTP/1.1 on http-443
Jun 1, 2006 5:21:08 PM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Jun 1, 2006 5:21:08 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/109 config=null
Jun 1, 2006 5:21:08 PM org.apache.catalina.storeconfig.StoreLoader load
INFO: Find registry server-registry.xml at classpath resource
Jun 1, 2006 5:21:08 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 1078 ms
FUDForum. Page generated in 0.01418 seconds
