| wtp1.02 new dynamicWebProject with default setting not working [message #169819] |
Tue, 23 May 2006 05:59  |
f fred Messages: 8 Registered: July 2009 |
Junior Member |
Hlo,
Just updated wtp to 1.02 version and made some test.
With a new fresh workspace, i tried the "dynamicWebProject" wizard, letting all parameters to default.
I create an index.html page in the webContent doc root and create a new server (with the "run as" function, or directly from the server tab) and got an error :
org.eclipse.core.runtime.CoreException: Could not load the Tomcat server configuration at /Servers/Tomcat v5.0 Server @ localhost-config. The configuration may be corrupt or incomplete.
I tried tomcat 5.0.30 and 5.5.12 with exactly the same result. My jdk is a 1.4.2, i'll soon with 1.5 and gave you results.
Do you experiment such problems ?
What are the "known working" requirements for tomcat, jdk , and jsp for that version ?
Thanks.
Fred
| Re: wtp1.02 new dynamicWebProject with default setting not working [message #169835 is a reply to message #169819] |
Tue, 23 May 2006 08:36  |
Larry Isaacs Messages: 1261 Registered: July 2009 |
Which OS are you using and what files do you see under "/Servers/Tomcat
v5.0 Server @ localhost-config"?
Larry
ffred wrote:
> Hlo,
> Thanks.
> Fred
FUDForum. Page generated in 0.02489 seconds
