| facet runtimes ? [message #169739] |
Sat, 20 May 2006 12:53  |
Max Rydahl Andersen Messages: 221 Registered: July 2009 |
From my understanding the facet's concept of a runtime-component is
independent of server runtimes, is that correct ?
e.g. a runtime-component does not need to be a "full" server definition,
but could also be a framework, e.g. Hibernate or JBPM.
My question is then:
Is there any examples of this somewhere ?
Is there any ui to manage those runtimes similar to the Installed Server
Runtimes ?
/max
| Re: facet runtimes ? [message #169747 is a reply to message #169739] |
Sat, 20 May 2006 12:59  |
I think runtime is not meant for frameworks - just realized that there
apparently only can be one runtime
associated to the facet enabled projects hence you cannot enable multiple
"framework-runtimes".
....I guess that the whole framework should be embodied in one or multiple
dependent facets then.
/max
> Runtimes ?
> /max
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
FUDForum. Page generated in 0.02212 seconds
