| Can't start WAS6 from Eclipse with WTP [message #169164] |
Thu, 11 May 2006 13:09  |
Originally posted by: jordicahue.es.ibm.com
Hi, I'm trying to start WAS6 server from Eclipse Server view but I get the
exception DescriptorParseException with the XML file
com/ibm/ws/management/descriptor/xml/JVM.xml.
On the other hand, I can start withot any problem my WAS6 server outside
Eclipse.
I would appreciate any help on this matter.
Thanks in advance, and sorry about spanish logs.
Jordi.
************ Start Display Current Environment ************
WebSphere Platform 6.0 [ND 6.0.0.1 o0445.08] running with process name
ESQ86734Node03Cell\ESQ86734Node03\server1 and process id 560
Host Operating System is Windows XP, version 5.1
Java version = 1.4.1_05, Java Compiler = null, Java VM name = Java
HotSpot(TM) Client VM
was.install.root = C:/IBM/WAS6/AppServer1
user.install.root = C:/IBM/WAS6/AppServer1/profiles/TF7AppSrv
Java Home = C:\Program Files\Java\j2re1.4.1_05
ws.ext.dirs =
C:/IBM/WAS6/AppServer1/java/lib;C:/IBM/WAS6/AppServer1/profi les/TF7AppSrv/classes;C:/IBM/WAS6/AppServer1/classes;C:/IBM/ WAS6/AppServer1/lib;C:/IBM/WAS6/AppServer1/installedChannels ;C:/IBM/WAS6/AppServer1/lib/ext;C:/IBM/WAS6/AppServer1/web/h elp;C:/IBM/WAS6/AppServer1/deploytool/itp/plugins/com.ibm.et ools.ejbdeploy/runtime
Classpath =
C:\IBM\WAS6\AppServer1\properties;C:\IBM\WAS6\AppServer1\lib \bootstrap.jar;C:\IBM\WAS6\AppServer1\lib\j2ee.jar;C:\IBM\WA S6\AppServer1\lib\lmproxy.jar;C:\IBM\WAS6\AppServer1\lib\url protocols.jar
Java Library path =
C:/IBM/WAS6/AppServer1/java/bin;C:/IBM/WAS6/AppServer1/bin;C :/IBM/WAS6/AppServer1/java/bin;C:/IBM/WAS6/AppServer1/java/j re/bin
************* End Display Current Environment *************
[11/05/06 18:48:34:804 CEST] 0000000a ManagerAdmin I TRAS0017I: El
estado de rastreo de arranque es *=info.
[11/05/06 18:48:34:964 CEST] 0000000a MBeanDescript W ADMN0001W: El
servicio no puede analizar el archivo descriptor de MBean
com/ibm/ws/management/descriptor/xml/mbeans.xml.
[11/05/06 18:48:35:065 CEST] 0000000a AdminInitiali A ADMN0015I: El
servicio de administración se ha inicializado.
[11/05/06 18:48:35:105 CEST] 0000000a MBeanDescript W ADMN0001W: El
com.ibm.websphere.management.exception.DescriptorParseExcept ion:
ADMN0001W: El servicio no puede analizar el archivo descriptor de MBean
com.ibm.ws.management.descriptor.MBeanDescriptorLoader.loadD escriptor(MBeanDescriptorLoader.java:164)
com.ibm.ws.management.descriptor.MBeanDescriptorManager.load DescriptorFile(MBeanDescriptorManager.java:319)
com.ibm.ws.management.descriptor.MBeanDescriptorManager.getD escriptor(MBeanDescriptorManager.java:133)
com.ibm.ws.management.MBeanFactoryImpl.activateMBean(MBeanFa ctoryImpl.java:375)
com.ibm.ws.management.MBeanFactoryImpl.activateMBean(MBeanFa ctoryImpl.java:348)
com.ibm.ws.management.component.AdminImpl.initialize(AdminIm pl.java:350)
com.ibm.ws.runtime.component.ContainerImpl.initializeCompone nt(ContainerImpl.java:1161)
com.ibm.ws.runtime.component.ContainerImpl.initializeCompone nts(ContainerImpl.java:1015)
at com.ibm.ws.runtime.component.ServerImpl.initialize(ServerImp l.java:245)
com.ibm.ws.runtime.WsServerImpl.bootServerContainer(WsServer Impl.java:157)
at com.ibm.ws.runtime.WsServerImpl.start(WsServerImpl.java:120)
at com.ibm.ws.runtime.WsServerImpl.main(WsServerImpl.java:378)
at com.ibm.ws.runtime.WsServer.main(WsServer.java:50)
at com.ibm.ws.bootstrap.WSLauncher.main(WSLauncher.java:190)
[11/05/06 18:48:35:135 CEST] 0000000a WsServerImpl E WSVR0009E: Se ha
producido un error durante el inicio
META-INF/ws-server-components.xml
[11/05/06 18:48:35:175 CEST] 0000000a WsServerImpl E WSVR0009E: Se ha
com.ibm.ws.exception.ConfigurationError:
com.ibm.ws.exception.ConfigurationError: Problem initializing AdminImpl:
com.ibm.ws.runtime.WsServerImpl.bootServerContainer(WsServer Impl.java:166)
Caused by: com.ibm.ws.exception.ConfigurationError: Problem initializing
AdminImpl:
com.ibm.ws.management.component.AdminImpl.initialize(AdminIm pl.java:697)
... 8 more
Caused by: com.ibm.ws.exception.ConfigurationWarning: Problem registering
JVM MBean.
com.ibm.ws.management.component.AdminImpl.initialize(AdminIm pl.java:361)
... 12 more
Caused by: com.ibm.websphere.management.exception.AdminException:
ADMN0005E: El servicio no puede activar MBean: tipo JVM, colaborador
com.ibm.ws.management.component.JVMMBean@4b29cf, ID de configuración JVM,
descriptor null.
com.ibm.ws.management.MBeanFactoryImpl.activateMBean(MBeanFa ctoryImpl.java:600)
... 12 more
Caused by:
... 14 more
| Re: Can't start WAS6 from Eclipse with WTP [message #169332 is a reply to message #169164] |
Fri, 12 May 2006 17:04  |
Dario Bassan Messages: 8 Registered: July 2009 |
Junior Member |
Hi Jordi,
I don't know exactly what happens but looking your log there is
something wrong on WAS JRE Env used to startup.
From your log:
Java version = 1.4.1_05, Java Compiler = null, Java VM name = Java Java
I think it should be:
Java version = J2RE 1.4.2 IBM Windows 32 build cn142ifx-20051115 (SR3 +
94164 + 97403 + 97482) (JIT enabled: jitc), Java Compiler = jitc, Java
VM name = Classic VM
Java Home = C:\IBM\WAS6\java\jre
Change your WAS configuration creating a new JRE definiton mapping to
"C:\IBM\WAS6\java\jre".
Hope this help.
Ciao
Dario
FUDForum. Page generated in 0.02778 seconds
