| Exception: org.apache.jasper.JasperException: /Result.jsp(10,0) [message #167722] |
Thu, 27 April 2006 11:19  |
Ben Sisson Messages: 202 Registered: July 2009 |
I created a Web Service from a WSDL, then generated cliets for the Web
Service using the WSDL. Running from Eclipse with the clients work fine.
I then wanted to move the clients to the server and access them from
there. I am running on Apache Tomcat 5.5.15.
I copied the 4 jsp files (TestClient, Result, Method, and Input) to the
C:\Program Files\Apache Software Foundation\Tomcat 5.5.15\webapps\ROOT
directory. I then started up the Tomcat server and chose the following
path: http://localhost:8080/TestClient.jsp on IE. The Methods and Input
sections of the client displayed my information fine. However, I received
an error in the Results section of the client.
I would appreciate any help with this. The entire error message that was
returned is as follows:
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it
from fulfilling this request.
exception
org.apache.jasper.JasperException: /Result.jsp(10,0) The value for the
useBean class attribute org.tempuri.Library_Support_ServicesSoapProxy is
invalid.
org.apache.jasper.servlet.JspServletWrapper.handleJspExcepti on(JspServletWrapper.java:510)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:375)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:314)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java :264)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
root cause
invalid.
org.apache.jasper.compiler.DefaultErrorHandler.jspError(Defa ultErrorHandler.java:39)
org.apache.jasper.compiler.ErrorDispatcher.dispatch(ErrorDis patcher.java:405)
org.apache.jasper.compiler.ErrorDispatcher.jspError(ErrorDis patcher.java:146)
org.apache.jasper.compiler.Generator$GenerateVisitor.visit(G enerator.java:1174)
org.apache.jasper.compiler.Node$UseBean.accept(Node.java:111 6)
org.apache.jasper.compiler.Node$Nodes.visit(Node.java:2163)
org.apache.jasper.compiler.Node$Visitor.visitBody(Node.java: 2213)
org.apache.jasper.compiler.Node$Visitor.visit(Node.java:2219 )
org.apache.jasper.compiler.Node$Root.accept(Node.java:456)
org.apache.jasper.compiler.Generator.generate(Generator.java :3304)
org.apache.jasper.compiler.Compiler.generateJava(Compiler.ja va:198)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:29 5)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:27 6)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:26 4)
org.apache.jasper.JspCompilationContext.compile(JspCompilati onContext.java:563)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:303)
note The full stack trace of the root cause is available in the Apache
Tomcat/5.5.15 logs.
Apache Tomcat/5.5.15
FUDForum. Page generated in 0.01750 seconds
