Home » Eclipse Projects » Web Tools Project (WTP) » Validation Framework API coming in WTP1.5?
Validation Framework API coming in WTP1.5? [message #163935] Tue, 14 March 2006 14:36 Go to next message
Eclipse User
Originally posted by: cchiu888.hotmail.com
Will the validation framework API
(org.eclipse.wst.validation.internal.provisional.core.IValid ator, etc) be
finalized in WTP 1.5? It is currently under the internal.provisional
namespace. I would prefer to stick with public finalized API. My scenario
is described below.
I created a custom facet for the web project and need to have a validator
associated with this facet. The validator checks whether the classes needed
to process my data files are available in the web-inf/lib classpath and flag
errors if they are missing.
This is probably similar to the builder concept associated with Eclipse
nature. But since I am using facet already, I'd like to avoid using nature
if I can.
If WTP1.5 does not make public IValidator, is there any other options
besides using a builder?
Thanks.
Re: Validation Framework API coming in WTP1.5? [message #167422 is a reply to message #163935] Tue, 25 April 2006 02:25 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
> is described below.
> if I can.
If you've been tracking recent developments, you've seen the ability
to run within a non-Build Job added to the framework. Requests to
formalize it as API should be made in Bugzilla, though.
- Nitin
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:Using the source
Next Topic:JSP and Tags
Current Time: Mon May 20 00:28:14 EDT 2013
Powered by FUDForum. Page generated in 0.01649 seconds
