Home » Eclipse Projects » Web Tools Project (WTP) » Writing a custom server plugin
Writing a custom server plugin [message #166346] Mon, 10 April 2006 02:43 Go to next message
Eclipse User
Originally posted by: dbassu.research.telcordia.com
Am trying to write a set of plugins to introduce mgmt. functionality for a
server using WST server API. Was looking around for some tutorial/article on
writing your own server plugins - didn't find much other than the API
itself. The source code for the JST was the other alternative but plouging
through that doesn't look like a simple task.
Any suggestions where to look and what would be a good starting point?
- Devasis
Re: Writing a custom server plugin [message #166468 is a reply to message #166346] Tue, 11 April 2006 12:54 Go to previous messageGo to next message
Lawrence Mandel is currently offline Lawrence Mandel
Hi Devasis,
Although I agree that digging through source code is not always a great
solution WTP does include several server adapters you may want to take a
look at for examples.
See
http://dev.eclipse.org/viewcvs/index.cgi/jst/components/serv er/plugins/?cvsroot=WebTools_Project
Lawrence
Re: Writing a custom server plugin [message #166635 is a reply to message #166346] Wed, 12 April 2006 15:27 Go to previous message
Gorkem Ercan is currently offline Gorkem Ercan
There was a tutorial in EclipseCon that covered server tools and facets
you can download the tutorial material
http://www.eclipsecon.org/2006/Sub.do?id=241 . This should provide a
good starting point
Gorkem
Devasis Bassu wrote:
> - Devasis
Previous Topic:WhatÂ’s New for Callisto?
Next Topic:WSDL Editor - unable to set type for a custom type element
Current Time: Wed May 22 13:06:26 EDT 2013
Powered by FUDForum. Page generated in 0.01533 seconds
