Home » Eclipse Projects » GEF » bug? about the DeleteAction
bug? about the DeleteAction [message #165654] Wed, 26 January 2005 05:28 Go to next message
Eclipse User
Originally posted by: zhlmmc.hotmail.com
Everything works well in my PicEditor,but when I set the PicEditor as a
subeditor of my MultiPageEditor,the DeleteAction doesn't work.(Redo and
Undo Action work well)
I have set globalActionHandler in setActivePage() of my
MultiPageContributor:
actionBars.setGlobalActionHandler(ActionFactory.DELETE.getId (),
getAction(editor, ActionFactory.DELETE.getId()));
I refered to the MultiPageEditorExample ,but it didn't help.
What's the problem?
Thanks.
Re: bug? about the DeleteAction [message #165811 is a reply to message #165654] Wed, 26 January 2005 19:37 Go to previous messageGo to next message
Pratik Shah is currently offline Pratik Shah
Do you invoke updateActionBars() after setting the new global action
handler?
"zhlmmc" <zhlmmc@hotmail.com> wrote in message
news:ct7rbt$e9i$1@www.eclipse.org...
> What's the problem?
> Thanks.
Re: bug? about the DeleteAction [message #165842 is a reply to message #165811] Wed, 26 January 2005 23:19 Go to previous messageGo to next message
Eclipse User
Of course,I invoke it.
I wander,why the Redo and Undo action work well,but the DeleteAction
doesn't work.
> handler?
>> What's the problem?
>> Thanks.
Re: bug? about the DeleteAction [message #166034 is a reply to message #165654] Thu, 27 January 2005 14:54 Go to previous messageGo to next message
Eclipse User
See GraphicalEditor#selectionChanged(). You shouldn't expect to use
MultiPageEditor and have the editors inside work normally. See bug 46207.
> What's the problem?
> Thanks.
Re: bug? about the DeleteAction [message #166171 is a reply to message #166034] Sat, 29 January 2005 05:23 Go to previous messageGo to next message
Eclipse User
I have read the bug reported at Bugzilla,but I don't understand it clearly.
I'm a novice to GEF.
Is there any example about GraphicalEditpr embeded in a MultiPageEditor?
I write selectionChanged() in my GraphicalEditor like this:
public void selectionChanged(IWorkbenchPart part, ISelection selection) {
if (part.getSite().getWorkbenchWindow().getActivePage() == null)
return;
super.selectionChanged(part, selection);
Any Problem?
>> What's the problem?
>> Thanks.
Re: bug? about the DeleteAction [message #166256 is a reply to message #166034] Sun, 30 January 2005 04:21 Go to previous messageGo to next message
Eclipse User
I have got it.
I should update the selectionActions by myself but not delegate it to the
super class.
Does this problem will be solved in 3.1?
>> What's the problem?
>> Thanks.
Re: bug? about the DeleteAction [message #166372 is a reply to message #166171] Mon, 31 January 2005 10:38 Go to previous message
Eclipse User
"zhlmmc" <zhlmmc@hotmail.com> escreveu na mensagem
news:ctfo6q$tuv$1@www.eclipse.org...
Basiclly, MultiPageEditor is a hack and editor's aren't designed to be
composed this way.
> Is there any example about GraphicalEditor embeded in a MultiPageEditor?
> return;
Did you look at super and the assumptions it is making?
Previous Topic:Get Focus
Next Topic:WYSIWYG HTML Editor
Current Time: Tue May 21 18:23:07 EDT 2013
Powered by FUDForum. Page generated in 0.01983 seconds
