| Demodata Initialization Problem Must be one current state. Found 0 for DBJ3X [message #16120] |
Mon, 29 June 2009 04:46  |
Andreas Graf Messages: 129 Registered: July 2009 |
Hi group,
when running the Demo Data Action from the John Hopkins example I get the
attached error. My system is still populated at least with some
requirements. Does anybody have an idea about what's wrong?
Thx,
Andreas
org.eclipse.osee.ats.util.widgets.XCurrentStateDam.getState( XCurrentStateDam.java:37)
org.eclipse.osee.ats.util.StateManager.getCurrentStateName(S tateManager.java:116)
org.eclipse.osee.ats.editor.SMAManager.isCompleted(SMAManage r.java:703)
org.eclipse.osee.ats.editor.SMAManager.isCancelledOrComplete d(SMAManager.java:711)
org.eclipse.osee.ats.artifact.StateMachineArtifact.getPercen tCompleteSMATotal(StateMachineArtifact.java:1168)
org.eclipse.osee.ats.util.widgets.XCurrentStateDam.logMetric s(XCurrentStateDam.java:63)
org.eclipse.osee.ats.util.widgets.XCurrentStateDam.updateMet rics(XCurrentStateDam.java:51)
org.eclipse.osee.ats.util.StateManager.updateMetrics(StateMa nager.java:137)
org.eclipse.osee.ats.util.StateManager.updateMetrics(StateMa nager.java:132)
org.eclipse.osee.ats.artifact.TeamWorkflowManager.setEndorse Data(TeamWorkflowManager.java:110)
org.eclipse.osee.ats.artifact.TeamWorkflowManager.transition To(TeamWorkflowManager.java:49)
org.eclipse.osee.ats.config.demo.config.PopulateDemoActions. createActions(PopulateDemoActions.java:406)
org.eclipse.osee.ats.config.demo.config.PopulateDemoActions. run(PopulateDemoActions.java:123)
org.eclipse.osee.ats.config.demo.config.PopulateDemoActions. run(PopulateDemoActions.java:92)
org.eclipse.osee.framework.ui.skynet.widgets.xnavigate.XNavi gateComposite.handleDoubleClick(XNavigateComposite.java:214)
org.eclipse.osee.ats.navigate.AtsNavigateComposite.handleDou bleClick(AtsNavigateComposite.java:92)
org.eclipse.osee.ats.navigate.AtsNavigateComposite.handleDou bleClick(AtsNavigateComposite.java:60)
org.eclipse.osee.framework.ui.skynet.widgets.xnavigate.XNavi gateComposite$3.handleEvent(XNavigateComposite.java:100)
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
java.lang.reflect.Method.invoke(Method.java:597)
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
org.eclipse.equinox.launcher.Main.run(Main.java:1236)
| Re: Demodata Initialization Problem Must be one current state. Found 0 for DBJ3 [message #17022 is a reply to message #16120] |
Fri, 24 July 2009 15:50   |
Nirmal Sasidharan Messages: 120 Registered: July 2009 Location: Germany |
Hello Andreas,
This is a bug in OSEE. OSEE doesn't seem to handle locale correctly. The
bug happens with German Locale settings in your OS. You could get over
this bug by passing "-nl en" argument to eclipse when you start the OSEE
client (if you are using oseeLocal.exe, add the argument to
oseeLocal.ini).
This bug causes OSEE to crash not only during Demo data population but at
many other places too.
OSEE is storing the Workflow Action States in the following format in the
database and tokening it later I guess.
<Action State>;<<Responsible Name>>;<Time taken>;<Percent complete>
For example, Authorize;<Joe Smith>;10.00;30
On the German Locale the third token 10.00 gets written as 10,00 and I
guess the tokeniser is broken here.
Also repeat a database intialisation, so that any corrupt values are
removed.
Somwehere OSEE is giving me a scare with such bugs!
See you in office on Monday ;)
Nirmal
| Re: Demodata Initialization Problem Must be one current state. Found 0 for DBJ3 [message #574762 is a reply to message #16120] |
Hello Andreas,
oseeLocal.ini).
removed.
Nirmal
| Re: Demodata Initialization Problem Must be one current state. Found 0 for DBJ3 [message #574788 is a reply to message #17022] |
Mon, 27 July 2009 07:54  |
Mark D-B Messages: 188 Registered: July 2009 |
The comma versus stop for decimal point problem is very common in software
that was originally written for a user base outside continental Europe. In
fairness to OSEE's developers, it is only as users in this area start
using the tool (with a geographic locale set, given that many users do not
use the full locale in order to avoid problems with other tools), that
such issues will manifest. OSEE is far from unique in not having tested
for this.
It will be interesting to see, when one of you has submitted this to OSEE
Bugzilla, whether the fault is in OSEE itself or another Eclipse component.
FUDForum. Page generated in 0.02025 seconds
