Home » Language IDEs » CDT » Build don't work if I only change files other than ".c"
Build don't work if I only change files other than ".c" [message #160712] Tue, 20 December 2005 07:18 Go to next message
Eclipse User
Originally posted by: fabricio.dea.inpe.br
I'm new to CDT and Eclipse (Linux), and I have two simple - and I think
basic - questions:
1) I'm using a Standard (not managed) C Make Project, and I noticed that
when I try to build, the make command only runs if there is a ".c" file
changed. If I change only a header or the makefile itself, the build
command don't call "make". Is it normal?
2) How to do a rebuild (clean + build)? In Preferences there is a field
called "rebuild", but there's no menu item for this.
Thank you in advance,
Fabrício.
Re: Build don't work if I only change files other than ".c" [message #160747 is a reply to message #160712] Tue, 20 December 2005 11:31 Go to previous messageGo to next message
Eclipse User
Originally posted by: berend.chalmers.se
In a standard make, you are responsible for the Makefile, which means
that you should put in the correct dependencies - on which header files
the C files depend.
Berend.
> basic - questions:
> Fabrício.
L_@~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~@
| Berend van Wachem |
| Multiphase Flow Group |
| Chalmers University of Technology |
| Please note that my email address has changed to: |
| Berend@chalmers.se |
| Please make the appropriate changes in your address |
| list. |
__@~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~@
\/______________________________________________________/
Re: Build don't work if I only change files other than ".c" [message #160772 is a reply to message #160747] Tue, 20 December 2005 13:31 Go to previous messageGo to next message
Eclipse User
Originally posted by: ddaoust.ca.ibm.com
I think that you missed the point of this post.
Eclipse has determined that "nothing interesting has changed" and so the
project builder (in this case the CDT builder) is NOT told to build the
project -- so make will not be called.
- Dave
Berend van Wachem wrote:
> the C files depend.
> Berend.
>> think basic - questions:
>> that when I try to build, the make command only runs if there is a
>> ".c" file changed. If I change only a header or the makefile itself,
>> the build command don't call "make". Is it normal?
>> field called "rebuild", but there's no menu item for this.
>> Fabrício.
Re: Build don't work if I only change files other than ".c" [message #160776 is a reply to message #160772] Tue, 20 December 2005 15:21 Go to previous messageGo to next message
Randy D. Smith is currently offline Randy D. Smith
No, I think he had the point of the post. The "or the makefile itself"
implies not having a lot of experience with make. I think the original
response is right... it goes back to having to be responsible for the
makefile in a non-managed make situation, which means also being
responsible for understanding the model make itself follows.
Back to the original questioner... If you change .c files, a re-compile
takes place. This is presumably because you have a
<whatever-target>: <whatever-c-files-it-is-dependent-upon>
dependency set up (or some default global settings are providing that
for you). Do you have
<whatever-specific-c-file>: <the-.h-it-depends-on>
dependency set up as well?
Now, I've been a long time *user* of makefiles, but not that much in the
development side... and I've never seen where everything is also
"dependent on" the makefile itself... though I agree it is a good idea.
RDS
> - Dave
>> files the C files depend.
>> Berend.
>>> Fabrício.
Re: Build don't work if I only change files other than ".c" [message #160863 is a reply to message #160776] Wed, 21 December 2005 07:51 Go to previous message
Eclipse User
Yes, Berend's right, and who missed the point here was me :)
I thought that "make" was not called by Eclipse, but after you answers I
looked again and saw that who was complaining that nothing was changed was
make.
Thank you all again, and sorry for so basic question!
Fabrício.
Previous Topic:Error Parser
Next Topic:Running and debugging an MPI application
Current Time: Sun May 19 00:59:24 EDT 2013
Powered by FUDForum. Page generated in 0.02481 seconds
