Home » Language IDEs » Java Development Tools (JDT) » source attachment with variable path
source attachment with variable path [message #147512] Fri, 05 March 2004 14:14 Go to next message
Eclipse User
Originally posted by: jpianezze.telephia.com
I want to attach source to a jar library.
It appears to be impossible to specify a source location relative to a
variable path name.
I can specify a location in the workspace, but the source is not usually in
the workspace.
I can specify a location somewhere in the file system, but I get a
hard-coded path in the .classpath file.
There are two types of such variables:
1. Linked Resources
2. Classpath variables.
It's not a classpath, it's really a linked resource. I can create a link for
each external toolkit for which I want to specify source, but this seems to
be a waste, and clutters the project.
John Pianezze
Re: source attachment with variable path [message #147726 is a reply to message #147512] Mon, 08 March 2004 09:42 Go to previous messageGo to next message
Darin Wright is currently offline Darin Wright
You can use a classpath variable for this. Create the variable, and then
attach the source using the variable as the prefix of the source attachment
path.
Darin
"John Pianezze" <jpianezze@telephia.com> wrote in message
news:c2ajbu$f4u$1@eclipse.org...
> variable path name.
in
> the workspace.
> 1. Linked Resources
for
to
> John Pianezze
Re: source attachment with variable path [message #147815 is a reply to message #147726] Mon, 08 March 2004 18:47 Go to previous messageGo to next message
Eclipse User
I tried that.
I define a "classpath variable" here:
Windows -> Preferences -> Java -> Classpath Variables
called "JUNIT_HOME"
The I choose the jar file, right-click, choose "java source attachment"
I type in JUNIT_HOME/junit3.8.1/src.jar
It says "the path ..... does not exist"
I tried $JUNIT_HOME
I tried %JUNIT_HOME%
When creating a new project, I can use this variable: "JUNIT_HOME" but after
that, it always uses the actual hard path ( i know this is a current feature
enhancement request)
Any other can you assist further?
John Pianezze
"Darin Wright" <Darin_Wright@ca.ibm.com> wrote in message
news:c2i0hn$fjv$1@eclipse.org...
> path.
> Darin
> > variable path name.
> in
> > the workspace.
> > 1. Linked Resources
> for
> to
> > John Pianezze
Re: source attachment with variable path [message #148152 is a reply to message #147815] Thu, 11 March 2004 09:19 Go to previous message
Not sure I fully understand the problem. Please file a bug with an explicit
test case.
Darin
news:c2j0f6$r8q$1@eclipse.org...
> I tried that.
> called "JUNIT_HOME"
> I tried $JUNIT_HOME
after
feature
> John Pianezze
> > path.
> > Darin
> > > variable path name.
usually
> > in
> > > the workspace.
> > > 1. Linked Resources
link
> > for
seems
> > to
> > > John Pianezze
Previous Topic:Can we block hot code replace from happening to 1 file?
Next Topic:Custom ASTNodes, OOP broken?
Current Time: Thu May 23 22:12:15 EDT 2013
Powered by FUDForum. Page generated in 0.01639 seconds
