Home » Eclipse Projects » Tigerstripe » UML Import
UML Import [message #13385] Fri, 30 January 2009 04:43 Go to next message
Marc FLAUW is currently offline Marc FLAUW
I am coming back to a subject that might have already been discussed
several times.
I have a UML model, the SID, in RSM 7.5. I have tried a simple import into
a blank Tigerstripe project.
I arrive at the model mapping part and I have nearly hundreds of objects
with a question mark.
Not being a specialist of the whole SID, I don't see how I can on the fly
modify all these mappings and furthermore, 2 different peoples doing the
same import are likely to make different choices.
Is there a way to automate this more? For instance, is there some
stereotypes that Tigerstripe recognizes that I can put in my RSM model to
indicate the type of artifact? or is there a way to record the choice of
mapping made in a config file that would be reused for subsequent mappings?
Marc
Re: UML Import [message #14464 is a reply to message #13385] Mon, 02 February 2009 10:12 Go to previous message
Ignore previous post. There is a SID Import plug-in that I thought was
part of the base product.
Marc
Re: UML Import [message #564342 is a reply to message #13385] Mon, 02 February 2009 10:12 Go to previous message
Marc
Previous Topic:Blanks in package names after import
Next Topic:Adding a relationship
Current Time: Wed May 22 09:01:27 EDT 2013
Powered by FUDForum. Page generated in 0.07276 seconds
