Home » Archived » Visual Editor (VE) » graphical SWT development
graphical SWT development [message #144108] Fri, 21 March 2008 13:05 Go to next message
Eclipse User
Originally posted by: nicolas.trahan.rogers.com
Hi everyone,
I've just installed the Visual Editor on Eclipse 3.2 using automated
updates at the Callisto Discovery Site. I'm interested in developing SWT
applications, however, the Palette only shows Swing and AWT components.
Also, when I open an existing SWT class, it just shows a blank screen.
How can I fix this?
Nicolas
Re: graphical SWT development [message #144146 is a reply to message #144108] Tue, 25 March 2008 09:43 Go to previous messageGo to next message
Yves YANG is currently offline Yves YANG
That means the swt container is not yet setup in the classpath of your
project. To do so, please call the wizard to create a type of SWT. The
container will be added automatically.
Best regards
Yves YANG
http://www.soyatec.com
"Nicolas" <nicolas.trahan@rogers.com> wrote in message
news:fs0ptj$cbg$1@build.eclipse.org...
> Hi everyone,
> How can I fix this?
> Nicolas
Re: graphical SWT development [message #144163 is a reply to message #144146] Wed, 26 March 2008 09:52 Go to previous messageGo to next message
Eclipse User
What do you mean when you say that "the swt container is not yet setup
in the classpath of your project"? I do have the swt.jar added in my
project (I can compile my program without any problems) if that's what
you mean. And what do you mean when you say "call the wizard to create a
type of SWT"? What wizard are you talking about? Where do I access it?
Also, I don't have the option to create a new visual class in the
File->New menu. I looked in my .metadata folder but I don't even have a
..log file.
Thank you very much for your help!
Nicolas
> Best regards
> Yves YANG
>> Hi everyone,
>> SWT applications, however, the Palette only shows Swing and AWT
>> components. Also, when I open an existing SWT class, it just shows a
>> blank screen.
>> How can I fix this?
>> Thanks,
>> Nicolas
Re: graphical SWT development [message #144181 is a reply to message #144163] Wed, 26 March 2008 10:44 Go to previous message
The swt.jar is not enough. The container I said is jar container, which
packages a group of the jars. You can find a JDK container when you create a
Java project.
To call wizard, you right-select a package in package explorer, and then
click on the context menu New->Others, you should have a Visual class if
your VE is installed correctly.
regards
Yves YANG
http://www.soaytec.com
news:fsdkev$pva$1@build.eclipse.org...
> What do you mean when you say that "the swt container is not yet setup in
> the classpath of your project"? I do have the swt.jar added in my project
> (I can compile my program without any problems) if that's what you mean.
> And what do you mean when you say "call the wizard to create a type of
> .log file.
> Nicolas
>> Best regards
>> Yves YANG
>>> Hi everyone,
>>> How can I fix this?
>>> Thanks,
>>> Nicolas
Re: graphical SWT development [message #617002 is a reply to message #144108] Tue, 25 March 2008 09:43 Go to previous message
Best regards
Yves YANG
> Hi everyone,
> How can I fix this?
> Nicolas
Re: graphical SWT development [message #617004 is a reply to message #144146] Wed, 26 March 2008 09:52 Go to previous message
Nicolas is currently offline Nicolas
..log file.
Nicolas
> Best regards
> Yves YANG
>> Hi everyone,
>> blank screen.
>> How can I fix this?
>> Thanks,
>> Nicolas
Re: graphical SWT development [message #617006 is a reply to message #144163] Wed, 26 March 2008 10:44 Go to previous message
Java project.
regards
Yves YANG
> .log file.
> Nicolas
>> Best regards
>> Yves YANG
>>> Hi everyone,
>>> How can I fix this?
>>> Thanks,
>>> Nicolas
Previous Topic:How can I display a grid as a background in the VE?
Next Topic:How does initialize() work?
Current Time: Sat May 25 03:22:14 EDT 2013
Powered by FUDForum. Page generated in 0.03932 seconds
