Home » Eclipse Projects » DSDP » Remote debugging question
Remote debugging question [message #14295] Sun, 30 November 2008 16:24 Go to next message
No real name is currently offline No real name
Member
Eclipse
Version: 3.4.1
Build id: M20080911-1700
PDT Core Plugin: 2.0.0v2008103
Xdebug 2.0.3
I've set up PDT/Xdebug to debug an app on a remote server. To
accomplish this, I basically start with a copy of the app on my local
machine and then upload that app to the remote machine with RSE. When I
make edits to the copies on the local machine I synchronize the app on
the remote machine with the app on my local machine.
Here's the problem:
The app that I'm running modifies the contents within its directory
tree, and as the app runs on the remote system(the server), its contents
are changed. So my local app is out of sync with my remote app, but my
local app is the one that should be updated.
Is there any way of getting RSE, to sync from the server to the client
on demand?
R
Re: Remote debugging question [message #14313 is a reply to message #14295] Wed, 03 December 2008 15:39 Go to previous message
Martin Oberhuber is currently offline Martin Oberhuber
Hi Richard,
this question should have gone to "eclipse.dsdp.tm" which is the
Newsgroup for RSE. I'm not sure what you mean by "Synchronize on Demand"
but I assume that you want to press a button to get modified files
downloaded (and only modified files).
RSE doesn't provide this out of the box, but will soon have it through a
Google Summer of Code contribution. Feel free to try it out:
http://wiki.eclipse.org/Platform/Team_Synchronization_on_top _of_RSE#Current_Status
If it were myself though, I guess I wouldn't employ RSE for the
synchronization but run rsync over ssh.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Richard Geddes wrote:
> Eclipse
> Version: 3.4.1
> Xdebug 2.0.3
> Here's the problem:
> on demand?
> Thanks
> R
Re: Remote debugging question [message #572358 is a reply to message #14295] Wed, 03 December 2008 15:39 Go to previous message
Hi Richard,
> Eclipse
> Version: 3.4.1
> Xdebug 2.0.3
> Here's the problem:
> on demand?
> Thanks
> R
Previous Topic:Remote debugging question
Next Topic:Eclipse C++ BB tutorial
Current Time: Wed May 29 02:03:29 EDT 2013
Powered by FUDForum. Page generated in 0.01658 seconds
