| Error trying to set new file into editor [message #142259] |
Tue, 23 October 2007 21:36  |
Originally posted by: andreiberi.look.ca
I am trying to run VE 1.3.0 build on Eclipse 3.3.1 and I am getting the
following error while trying to open a visual class:
"Error trying to set new file into editor. Reason:
java.lang.NullPointerException".
I googled it and it turns out that other people experienced the same
problem on earlier versions of VE.
Anybody has any ideas how to get around this problem?
Andrei
| Re: Error trying to set new file into editor [message #142279 is a reply to message #142269] |
Wed, 24 October 2007 23:26   |
I cleaned all projects and the problem went away. However it is
reoccurring intermittently.
What are the current plans for releasing official 1.3 version of VE?
Here is the stack trace of the exception:
!ENTRY org.eclipse.ve.java.core 2 0 2007-10-24 22:09:09.609
!MESSAGE Exception thrown.
!STACK 0
org.eclipse.ve.internal.java.codegen.java.AbstractContainerA ddDecoderHelper.getIndexedEntries(AbstractContainerAddDecode rHelper.java:410)
org.eclipse.ve.internal.swt.codegen.CompositeAddDecoderHelpe r.getIndexPriority(CompositeAddDecoderHelper.java:502)
org.eclipse.ve.internal.java.codegen.java.ExpressionDecoderH elper.getPriorityOfExpression(ExpressionDecoderHelper.java:1 38)
org.eclipse.ve.internal.java.codegen.java.AbstractExpression Decoder.determinePriority(AbstractExpressionDecoder.java:67)
org.eclipse.ve.internal.java.codegen.model.CodeExpressionRef .getPriority(CodeExpressionRef.java:182)
org.eclipse.ve.internal.java.codegen.model.CodeMethodRef.add ExpressionToSortedList(CodeMethodRef.java:604)
org.eclipse.ve.internal.java.codegen.model.CodeMethodRef.sor tExpressions(CodeMethodRef.java:702)
org.eclipse.ve.internal.java.codegen.model.CodeMethodRef.upd ateExpressionOrder(CodeMethodRef.java:710)
org.eclipse.ve.internal.java.codegen.java.ExpressionRefFacto ry.createFromJVEModel(ExpressionRefFactory.java:109)
org.eclipse.ve.internal.java.codegen.java.ExpressionRefFacto ry.createInitExpression(ExpressionRefFactory.java:74)
org.eclipse.ve.internal.java.codegen.util.AbstractMethodText Generator.createInitExpression(AbstractMethodTextGenerator.j ava:300)
org.eclipse.ve.internal.java.codegen.util.AbstractMethodText Generator.generateInLine(AbstractMethodTextGenerator.java:31 7)
org.eclipse.ve.internal.java.codegen.java.BeanPartFactory.ge nerateLocalVariable(BeanPartFactory.java:78)
org.eclipse.ve.internal.java.codegen.java.BeanPartFactory.cr eateFromJVEModel(BeanPartFactory.java:670)
org.eclipse.ve.internal.java.codegen.model.BeanDeclModel.laz yCreateBeanInstance(BeanDeclModel.java:305)
org.eclipse.ve.internal.java.codegen.model.BeanDeclModel.get ABean(BeanDeclModel.java:324)
org.eclipse.ve.internal.java.codegen.java.ChildRelationshipD ecoderHelper.getCurrentAddedPart(ChildRelationshipDecoderHel per.java:251)
org.eclipse.ve.internal.java.codegen.java.ChildRelationshipD ecoderHelper.generate(ChildRelationshipDecoderHelper.java:50 1)
org.eclipse.ve.internal.java.codegen.java.AbstractExpression Decoder.generate(AbstractExpressionDecoder.java:194)
org.eclipse.ve.internal.java.codegen.model.CodeExpressionRef .generateSource(CodeExpressionRef.java:361)
org.eclipse.ve.internal.java.codegen.java.ExpressionRefFacto ry.createFromJVEModel(ExpressionRefFactory.java:102)
org.eclipse.ve.internal.java.codegen.java.BeanDecoderAdapter .setElement(BeanDecoderAdapter.java:245)
org.eclipse.ve.internal.java.codegen.java.BeanDecoderAdapter .notifyChanged(BeanDecoderAdapter.java:458)
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:247)
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$InternalSe ttingDelegateSingleEObject.dynamicSet(EStructuralFeatureImpl .java:2425)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet(Basi cEObjectImpl.java:1116)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1090)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1061)
org.eclipse.ve.internal.cde.commands.ApplyAttributeSettingCo mmand.execute(ApplyAttributeSettingCommand.java:70)
org.eclipse.ve.internal.propertysheet.common.commands.Compou ndCommand.execute(CompoundCommand.java:224)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorCommandStack$1.run(JavaVisualEditorCommandStack.java:55)
org.eclipse.ve.internal.cde.core.ModelChangeController.doMod elChanges(ModelChangeController.java:245)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorCommandStack.execute(JavaVisualEditorCommandStack.java:5 2)
org.eclipse.ve.internal.swt.GridLayoutComponentPage.execute( GridLayoutComponentPage.java:866)
org.eclipse.ve.internal.swt.GridLayoutComponentPage$GrabActi on.run(GridLayoutComponentPage.java:470)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$4.handleEven t(ActionContributionItem.java:375)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Andrei
Yves YANG wrote:
> Please give more information such as stacktrace or a test-case ! It is hard
> to guess what is wrong.
> Best regards
> Yves YANG
> eFace: XAML for java (http://www.soyatec.com)
> "Andrei Beri" <andreiberi@look.ca> wrote in message
> news:ffm7ia$c8r$1@build.eclipse.org...
>> Thanks,
>> Andrei
| Re: Error trying to set new file into editor [message #142334 is a reply to message #142279] |
Thu, 25 October 2007 13:49  |
Yves YANG Messages: 686 Registered: July 2009 |
Thru the stacktrace, I cannot figure out how this case occurs. I will be
helpful if you can post a testcase.
Yves YANG
news:ffp2ci$rk3$1@build.eclipse.org...
>I cleaned all projects and the problem went away. However it is reoccurring
>intermittently.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Andrei
>> hard to guess what is wrong.
>> Best regards
>> Yves YANG
>>> Thanks,
>>> Andrei
| Re: Error trying to set new file into editor [message #616800 is a reply to message #142259] |
Wed, 24 October 2007 06:03  |
Best regards
Yves YANG
> Andrei
| Re: Error trying to set new file into editor [message #616801 is a reply to message #142269] |
!STACK 0
Andrei
> Best regards
> Yves YANG
>> Thanks,
>> Andrei
| Re: Error trying to set new file into editor [message #616806 is a reply to message #142279] |
Yves YANG
>intermittently.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Andrei
>> Best regards
>> Yves YANG
>>> Thanks,
>>> Andrei
FUDForum. Page generated in 0.12078 seconds
