| VE plugin hangs [message #141487] |
Wed, 03 October 2007 04:07  |
Originally posted by: dave.digitalbanana.org
Please can you help - Iam new to the Eclipse IDE having previously coded
using Textpad and ANT. I was sucessfully using the Visual Editor Plugin
but it has suddenly stopped working - It hangs at "Setup Java Visual
Editor: (25%)" if i look at the progress it says "Building Model: Parsing
Source". Something has changed configuration because classes that were
previously working fine will now not open at all. I tried to create a new
visual class via the right click menu (ie New>Other>Visual Class) and it
goes through fine until i click finish when the same thing happens.
Please help this is driving me mad
Dave Lowe
| Re: VE plugin hangs [message #141498 is a reply to message #141487] |
Wed, 03 October 2007 04:23  |
sorry - i've just seen there are similar postings already made about this
issue - i'll work through those and hopefully fix it
"dave lowe" <dave@digitalbanana.org> wrote in message
news:28a7da29d83dd31945b35292a377ddd5$1@www.eclipse.org...
> Thanks
> Dave Lowe
| Re: VE plugin hangs [message #616643 is a reply to message #141487] |
> Thanks
> Dave Lowe
FUDForum. Page generated in 0.01475 seconds
