Home » Archived » IAM (Eclipse Integration for Apache Maven) » Web Tools integration in q4e
Web Tools integration in q4e [message #5350] Wed, 19 March 2008 16:41 Go to next message
Abel Mui is currently offline Abel Mui
We've just finished the infrastructure for integrating with other plug-ins
for configuring maven projects.
The first example of this integration is for maven projects with war
packaging, which are configured with the Dynamic Web Project facets from
Web Tools Project.
It is still work in progress, but if you want to check it out, it can be
installed from the q4e development update site:
http://q4e.googlecode.com/svn/trunk/updatesite-dev/
The current feature set includes:
- Integration with the new project and project import wizards.
* If you're packaging is war, the project should automatically be WTP
enabled.
- Filtering of deployed artifacts
* Only artifacts with default scope or compile scope will be deployed
to your testing server.
Usual WTP features like hot deployment of modified java files and
resources, debugging and so on are also working.
There is an screencast available at http://tinyurl.com/ynqewf
Yours,
Abel Muiño.
Re: Web Tools integration in q4e [message #6702 is a reply to message #5350] Sun, 23 March 2008 03:05 Go to previous messageGo to next message
Eclipse User
Originally posted by: rinku.apache.org
The screencast link comes back with a 404.
Rahul
> plug-ins for configuring maven projects.
> Web Tools Project.
> enabled.
> * Only artifacts with default scope or compile scope will be deployed to
> Yours,
> Abel Muiño.
Re: Web Tools integration in q4e [message #6709 is a reply to message #6702] Sun, 23 March 2008 17:32 Go to previous messageGo to next message
The bandwidth offered by the service was exceeded.
Joakim Erdfelt is kindly hosting the screencast at:
http://joakim.erdfelt.com/q4e/q4e-wtp.swf
Sorry for the inconveniences!
Abel Muiño.
Rahul T wrote:
> Rahul
>> Web Tools Project.
>> enabled.
>> Yours,
>> Abel Muiño.
ZLbDKkZJBhwBBHIDyS [message #14026 is a reply to message #6709] Fri, 22 August 2008 00:09 Go to previous message
Eclipse User
Originally posted by: rteaac.prjcpb.com
Imzf8g <a href="http://sktrhoypxcgh.com/">sktrhoypxcgh</a>,
ynvtsbjjsibf,
kzjcksiaxzow[/link],
http://nhwfobtbzqoa.com/
Re: Web Tools integration in q4e [message #565277 is a reply to message #5350] Sun, 23 March 2008 03:05 Go to previous message
Eclipse User
Rahul
> Web Tools Project.
> enabled.
> Yours,
> Abel Muiño.
Re: Web Tools integration in q4e [message #565302 is a reply to message #6702] Sun, 23 March 2008 17:32 Go to previous message
Abel Muiño.
Rahul T wrote:
> Rahul
>> Web Tools Project.
>> enabled.
>> Yours,
>> Abel Muiño.
ZLbDKkZJBhwBBHIDyS [message #567287 is a reply to message #6709] Fri, 22 August 2008 00:09 Go to previous message
Eclipse User
ynvtsbjjsibf,
Previous Topic:An internal error occurred during: "Updating classpath container: core".
Next Topic:Spam
Current Time: Tue May 21 11:13:23 EDT 2013
Powered by FUDForum. Page generated in 0.07240 seconds
