Home » Eclipse Projects » MST » OCL text editor
OCL text editor [message #1346] Sat, 18 October 2008 07:02 Go to next message
An OCL text editor is available now from the M2M QVT Declarative CVS.
This editor uses IMP to provide the usual syntax coloring, folding, and
completion proposals. MDT-OCL and LPG provide the CST and AST parsing.
The (now QVT Declarative) Model Registry binds the external models to
support semantic validation.
At present it supports a complete OCL text file (a sequence of scoped
constraints). It could be no doubt adapted to support individual
constraints as a pop-up from a UML graphical editor.
For MST, the utility would be support for validated bulk entry of the
large number of OCL statements that occur in the better specifications
and that should occur in all specifications.
Ed Willink
Re: OCL text editor [message #1354 is a reply to message #1346] Mon, 20 October 2008 08:28 Go to previous messageGo to next message
Eclipse User
Originally posted by: Kenn.Hussey.embarcadero.com
Ed,
I agree that such functionality would indeed be useful for validating
constraints that are defined in a standard metamodel. We plan to use the
Papyrus environment as a basis for diagram editors in MST... have you
proposed this as an inclusion in Papyrus and/or compared/contrasted it with
plans that team has regarding OCL?
Kenn
"Ed Willink" <ed@willink.me.uk> wrote in message
news:gdcfop$rt4$1@build.eclipse.org...
> Hi
> completion proposals. MDT-OCL and LPG provide the CST and AST parsing. The
> (now QVT Declarative) Model Registry binds the external models to support
> large number of OCL statements that occur in the better specifications and
> Regards
> Ed Willink
Re: OCL text editor [message #1360 is a reply to message #1354] Wed, 22 October 2008 04:52 Go to previous messageGo to next message
Patrick Tessier is currently offline Patrick Tessier
We are very interesting by this fucntionnality in Papyrus.
In the OCL project can we put ocl constraint on profile, and validate theses
rules when we apply profile on model?
It could be very interesting to connect directly your ocl editor in the
diagram in order to see colored syntax.
Patrick
"Kenn Hussey" <Kenn.Hussey@embarcadero.com> a
Re: OCL text editor [message #1366 is a reply to message #1360] Mon, 27 October 2008 11:39 Go to previous messageGo to next message
Eclipse User
Originally posted by: cdamus.zeligsoft.com
Hi, Patrick,
The UML metamodel binding in the OCL component supports the definition
of constraints on Stereotypes in Profiles. As a convenience, the UML
environment allows evaluation of a constraint defined in the stereotype
context on an Element to which the stereotype is applied; it does this
by finding the associated stereotype instance and evaluating the
constraint on it, under the covers. The constraint must be well-formed
with respect to the stereotype properties, in particular using
navigation of metaclass extensions to access UML elements. There is no
syntactic short-cut for access to UML attributes in the stereotype context.
Does that answer your question?
Christian
> Best regards,
> Patrick
> "Kenn Hussey" <Kenn.Hussey@embarcadero.com> a écrit dans le message de news:
> gdhthh$cii$1@build.eclipse.org...
>> Ed,
>> with plans that team has regarding OCL?
>> Kenn
>>> Hi
>>> Regards
>>> Ed Willink
Re: OCL text editor [message #1372 is a reply to message #1366] Tue, 28 October 2008 05:50 Go to previous messageGo to next message
Yes,
As soon as I have time, I will contact you in order to connect your editor
into the property view in a first time and then directly on the diagram.
Patrick,
"Christian W. Damus" <cdamus@zeligsoft.com> a
Re: OCL text editor [message #1378 is a reply to message #1372] Tue, 28 October 2008 09:37 Go to previous messageGo to next message
Eclipse User
Hi, Patrick,
By "contact you," you do mean "contact the OCL newsgroup," right?
:-D
In the mean-time, you can see how OCL works with stereotypes in the
org.eclipse.ocl.uml.tests.ProfilesTest class.
cW
> Yes,
> Patrick,
> "Christian W. Damus" <cdamus@zeligsoft.com> a écrit dans le message de news:
> ge4nba$lv7$1@build.eclipse.org...
>> Hi, Patrick,
>> The UML metamodel binding in the OCL component supports the definition of
>> context on an Element to which the stereotype is applied; it does this by
>> finding the associated stereotype instance and evaluating the constraint
>> on it, under the covers. The constraint must be well-formed with respect
>> to the stereotype properties, in particular using navigation of metaclass
>> extensions to access UML elements. There is no syntactic short-cut for
>> Cheers,
>> Christian
>>> theses rules when we apply profile on model?
>>> Best regards,
>>> Patrick
>>> news: gdhthh$cii$1@build.eclipse.org...
>>>> Ed,
>>>> Kenn
>>>>> Hi
>>>>> Regards
>>>>> Ed Willink
Re: OCL text editor [message #1384 is a reply to message #1378] Wed, 29 October 2008 04:57 Go to previous messageGo to next message
Sebastien Gerard is currently offline Sebastien Gerard
Hi Christian,
do you if some guys, may be you, of the OCL group could work on the
integration of the OCL support (including the OCL editor) within Papyurs? Of
course, Patrick can help doing that.
--S
Re: OCL text editor [message #1391 is a reply to message #1384] Wed, 29 October 2008 10:59 Go to previous messageGo to next message
Eclipse User
Hi, Sébastien,
Naturally, I am interested in helping with that. The question is how
thinly I can spread myself ... :-)
Several features that are planned for OCL in this release should help
the integration, such as providing .edit and .editor plugins for the
metamodels and other work that Ed Willink is contributing. I think hes
has also expressed interest in contributing to MST, which probably
reaches into Papyrus as well.
Speaking for myself, working on the Papyrus side of any integration,
although I would undoubtedly enjoy it, is likely to be beyond my means.
We shall have to see in what little ways I can pitch in.
Christian
Sébastien Gérard wrote:
> Hi Christian,
> --Séb
> ge74in$dfi$1@build.eclipse.org...
>> Hi, Patrick,
>> :-D
>> cW
>>> Yes,
>>> editor into the property view in a first time and then directly on the
>>> diagram.
>>> Patrick,
>>> news: ge4nba$lv7$1@build.eclipse.org...
>>>> Hi, Patrick,
>>>> context.
>>>> Cheers,
>>>> Christian
>>>>> Best regards,
>>>>> Patrick
>>>>>> Ed,
>>>>>> the Papyrus environment as a basis for diagram editors in MST... have
>>>>>> you proposed this as an inclusion in Papyrus and/or
>>>>>> compared/contrasted it with plans that team has regarding OCL?
>>>>>> Kenn
>>>>>>> Hi
>>>>>>> and completion proposals. MDT-OCL and LPG provide the CST and AST
>>>>>>> parsing. The (now QVT Declarative) Model Registry binds the external
>>>>>>> models to support semantic validation.
>>>>>>> specifications and that should occur in all specifications.
>>>>>>> Regards
>>>>>>> Ed Willink
Re: OCL text editor [message #1396 is a reply to message #1391] Thu, 30 October 2008 04:12 Go to previous messageGo to next message
Hi.
Sorry, I don't read newsgroups very often.
I was firstly highlighting the availability of OCL editing support in
case you wanted it. It seems you do. I can assist in making the editor
invokable in an alternate fashion, but have limited time available to do
more than that.
Ed Willink
Re: OCL text editor [message #1402 is a reply to message #1396] Thu, 30 October 2008 09:10 Go to previous message
Eclipse User
Hi, Ed,
Don't worry; budgeting time is a fact of Eclipse committer life. I
wasn't trying to speak for you. :-)
I do have a plan item for this release to deliver the generated .edit
and .editor plug-ins, in a separately downloadable feature. An OCL text
editor is not in the plan.
cW
>> hes has also expressed interest in contributing to MST, which probably
>> means. We shall have to see in what little ways I can pitch in.
> Hi.
> more than that.
> Regards
> Ed Willink
Re: OCL text editor [message #563178 is a reply to message #1346] Mon, 20 October 2008 08:28 Go to previous message
Kenn Hussey is currently offline Kenn Hussey
Ed,
Kenn
> Hi
> Regards
> Ed Willink
Re: OCL text editor [message #563199 is a reply to message #1354] Wed, 22 October 2008 04:52 Go to previous message
Patrick
Re: OCL text editor [message #563224 is a reply to message #1360] Mon, 27 October 2008 11:39 Go to previous message
Eclipse User
Hi, Patrick,
Christian
> Best regards,
> Patrick
>> Ed,
>> Kenn
>>> Hi
>>> Regards
>>> Ed Willink
Re: OCL text editor [message #563249 is a reply to message #1366] Tue, 28 October 2008 05:50 Go to previous message
Yes,
Patrick,
Re: OCL text editor [message #563275 is a reply to message #1372] Tue, 28 October 2008 09:37 Go to previous message
Eclipse User
Hi, Patrick,
:-D
cW
> Yes,
> Patrick,
>> Hi, Patrick,
>> Cheers,
>> Christian
>>> Best regards,
>>> Patrick
>>>> Ed,
>>>> Kenn
>>>>> Hi
>>>>> Regards
>>>>> Ed Willink
Re: OCL text editor [message #563298 is a reply to message #1378] Wed, 29 October 2008 04:57 Go to previous message
Hi Christian,
--S
Re: OCL text editor [message #563326 is a reply to message #1384] Wed, 29 October 2008 10:59 Go to previous message
Eclipse User
Hi, Sébastien,
Christian
> Hi Christian,
> --Séb
>> Hi, Patrick,
>> :-D
>> cW
>>> Yes,
>>> diagram.
>>> Patrick,
>>>> Hi, Patrick,
>>>> context.
>>>> Cheers,
>>>> Christian
>>>>> Best regards,
>>>>> Patrick
>>>>>> Ed,
>>>>>> Kenn
>>>>>>> Hi
>>>>>>> Regards
>>>>>>> Ed Willink
Re: OCL text editor [message #563349 is a reply to message #1391] Thu, 30 October 2008 04:12 Go to previous message
Hi.
more than that.
Ed Willink
Re: OCL text editor [message #563371 is a reply to message #1396] Thu, 30 October 2008 09:10 Go to previous message
Eclipse User
Hi, Ed,
cW
> Hi.
> more than that.
> Regards
> Ed Willink
Previous Topic:OCL text editor
Next Topic:[Announce] MDT at EclipseCon 2009
Current Time: Sun May 19 06:43:32 EDT 2013
Powered by FUDForum. Page generated in 0.04339 seconds
