| Error occurred during initialization of VM [message #138191] |
Sun, 16 November 2008 08:31  |
Dan Zeller Messages: 6 Registered: July 2009 |
Junior Member |
Computer: 64-bit AMD
System: Vista Ultimate x64
Java: 1.5.0_15 (tried both x32 and x64)
Variables:
CLASSPATH
.;C:\Program Files (x86)\Java\jre1.5.0_15\lib
JAVA_HOME
JAVA_PROFILER_HOME
%TPTP_AC_HOME%\plugins\org.eclipse.tptp.javaprofiler
Path
%JAVA_PROFILER_HOME%;%SystemRoot%\system32;%SystemRoot%;%Sys temRoot%\System32\Wbem;C:\Program
Files (x86)\QuickTime\QTSystem\;%TPTP_AC_HOME%\bin;%JAVA_HOME%\bin
TPTP_AC_HOME
C:\Program Files (x86)\eclipseAC
TPTP Agent Controller: Tried both 4.0.1 and 4.0.0
Parameters tried:
-agentlib:JPIBootLoader=JPIAgent:server=standalone,help;Heap Prof
Respective output:
agent library failed to init: JPIBootLoader
Illegal TIAgent option
I ran setconfig.bat after each installation. Start the ACServer as
Administrator. Every item I am using is the runtime version, not sdk.
Any help to get this working would be appreciated. Dan
| Re: Error occurred during initialization of VM [message #138314 is a reply to message #138271] |
Tue, 18 November 2008 10:20   |
Eugene Chan Messages: 287 Registered: July 2009 |
Hi Dan,
Try VM arguent
'-agentlib:JPIBootLoader=JPIAgent:server=enabled;CGProf'
or
'-agentlib:JPIBootLoader=JPIAgent:server=controlled;CGProf'
That should give you an agent to attach to in the workbench.
For detail about the syntax of the command, please refer to
http://dev.eclipse.org/viewcvs/index.cgi/platform/org.eclips e.tptp.platform.agentcontroller/src-native-new/packaging_md/ windows/getting_started.html?root=TPTP_Project&view=co#J ava_15
Eugene
"Dan Zeller" <danwzeller@hotmail.com> wrote in message
news:ce6ae92669f63deaaa70cd0de3c9188c$1@www.eclipse.org...
> Eugene Chan wrote:
>> Hi Dan,
>> Could you verify that:
>> 1. JPIBootLoader library is available under the %JAVA_PROFILER_HOME%
>> folder?
>> 2. Try VM arguent
>> '-agentlib:JPIBootLoader=JPIAgent:server=standalone;CGProf'
>> Eugene
> Thank you for responding Eugene,
> 1. JPIBootLoader is in %JAVA_PROGILER_HOME% folder
> 2. Your argument does run my program (as does my previous without
> '...,help...'), but does not make it available under eclipse->Run->Profile
> Configurations(Attach to Agent
> configuration)(Host:localhost[10006])->Agents
> If I add '...,help...', I get:
> @(#)JVMTI Agent version 1.0.0.1
> Usage: (followed by agentlib usage help)
> So I assume I need to find a way to get JPIBootLoader to load. Also,
> SampleClient.exe does function.
> Dan
| Re: Error occurred during initialization of VM [message #138332 is a reply to message #138314] |
Tue, 18 November 2008 12:33   |
Junior Member |
Eugene Chan wrote:
> Hi Dan,
> Try VM arguent
> or
> Eugene
Eugene,
Tried both. Neither provides an available agent in eclipse under any
ports(10002, 10003, 10005, or 10006). The second, however, hangs there as
if it is waiting for me to attach, which I can't; therefore, it never
launches my java program.
As far as the ports, I think 10002 is my IAC and it tests good. Port
10003 does not test good. Both ports 10005 and 10006 test good.
I am wondering if the part of the error reading '@(#)JVMTI Agent version
1.0.0.1' tells us anything.
I downloaded the 4.5.1 JVMTI Profiler from the website, but it only
replaced what I think was the same thing in my eclipseAC plugins folder.
I know this must be frustrating for you, it is for me. I have been at
this thing for a couple weeks. Thank you for your help. Please let me
know next step.
Dan
| Re: Error... (SOLVED) [message #138341 is a reply to message #138332] |
Tue, 18 November 2008 12:56  |
Junior Member |
OK Eugene,
My response to your questions made me evaluate my ports. The ACServer
won't launch if the IAC is running. I had been trying to attach to 10006
the whole time, but I needed to attach to 10002. This provided, with your
CGProf an Execution Time Analysis as an agent. When I profile it, it runs
the application.
Thank you for your work on this, it's been really valuable to me to get
this solved. Please look for future post when I try to evaluate two
machines from a third.
Dan
FUDForum. Page generated in 0.06743 seconds
