Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » Improvement: "Open Source" action shows source code of given class instead of the place wh
Improvement: "Open Source" action shows source code of given class instead of the place wh [message #137860] Sun, 02 November 2008 05:57 Go to next message
hanys is currently offline hanys
I have one idea for improvement due to use case of searching for memory
leaks:
Improvement: Open Source action shows source code of given class instead of
the place where particular object was created
-Jan
Re: Improvement: "Open Source" action shows source code of given class instead of the plac [message #137905 is a reply to message #137860] Mon, 03 November 2008 10:12 Go to previous message
Eugene Chan is currently offline Eugene Chan
Hi Jan,
Thanks very much for using TPTP and suggestion on improvement. TPTP is very
happy to see feedback from user of the community.
The 'Open Source' action actually should open the class of the object
selected in the Java editor, instead of where the object is created.
Eugene
"Jan" <ahanys@seznam.cz> wrote in message
news:gek12u$b0v$1@build.eclipse.org...
> Hello,
> leaks:
> of the place where particular object was created
> -Jan
Previous Topic:Problem with navigation from Object References view to source code for anonymous inner classes
Next Topic:Using TPTP to profile the osgi application in Equinox Framework
Current Time: Wed May 22 09:01:05 EDT 2013
Powered by FUDForum. Page generated in 0.08783 seconds
