Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » 4.5.1 IAC profiling failure: org.eclipse.tptp.jvmti unavailable: JPIBootLoader
4.5.1 IAC profiling failure: org.eclipse.tptp.jvmti unavailable: JPIBootLoader [message #136693] Thu, 02 October 2008 16:38 Go to next message
Steven Emmerson is currently offline Steven Emmerson
I can't profile a JUnit test-class using the Integrated Agent Controller
from within the Eclipse IDE. When I try, the following output appears in
the Eclipse Console:
Error occurred during initialization of VM
Could not find agent library on the library path or in the local
directory: JPIBootLoader
and a widget eventually pops-up with the following message:
The JVMTI agent org.eclipse.tptp.jvmti is not available. Make sure that
the libraries for the agent are available and that it is configured
properly.
Please help.
Here's my environment:
$ uname -a
Linux gilda.unidata.ucar.edu 2.6.26.3-14.fc8 #1 SMP Wed Sep 3 03:17:52 EDT
2008 x86_64 x86_64 x86_64 GNU/Linux
$ The following environment variables are not set: LD_LIBRARY_PATH,
JAVA_PROFILER_HOME, TPCP_AC_HOME
$ Within Eclipse, selecting "Help -> About Eclipse SDK" shows
Eclipse SDK
Version: 3.4.0
Build id: I20080617-2000
$ I used "Help -> Software Updates" to install TPTP 4.5.1v200807310709-...
$ Within Eclipse, selecting "Help -> About Eclipse SDK -> Plug-in Details"
shows that "TPTP Linux_em64t IAC Plug-in v4.4.1v200808290100" is installed
$ The "Monitor" tab under "Profile Configurations" has only "Execution
Time Analysis" selected; its "Edit Options" shows only "Show Execution
Flow Graphical Details" selected.
Re: 4.5.1 IAC profiling failure: org.eclipse.tptp.jvmti unavailable: JPIBootLoader [message #136765 is a reply to message #136693] Fri, 03 October 2008 12:00 Go to previous messageGo to next message
Eugene Chan is currently offline Eugene Chan
Hi Steven,
How did you start the JUnit test class profile?
It sounds like the system variable cannot be located by the IAC, which is
tested and worked.
If you manually add the system variable and restart Eclipse, does it work
for you?
Eugene
"Steven Emmerson" <emmerson@ucar.edu> wrote in message
news:8ee595e380a1cd01dd91a1dd38ffade5$1@www.eclipse.org...
> properly.
> Please help.
> $ uname -a
> Eclipse SDK
> Version: 3.4.0
Re: 4.5.1 IAC profiling failure: org.eclipse.tptp.jvmti unavailable: JPIBootLoader [message #136777 is a reply to message #136765] Fri, 03 October 2008 12:48 Go to previous messageGo to next message
Hi Eugene,
Something very strange has happened. The same Eclipse process that
wouldn't profile at the end-of-work yesterday is profiling today at the
beginning-of-work. I didn't do anything in the interim, so I'm at a loss
to explain this. I do have my Eclipse set-up for automatic download of
updates. I wonder if that's the cause. We also have nightly automatic
updates pushed to our workstations for system software (e.g., libraries,
utilities).
I did execute the script
" plugins/org.eclipse.tptp.platform.ac.linux_em64t_4.4.1.v2008 08290100/agent_controller/bin/SetConfig.sh "
while that Eclipse process was running, but I believe I tried profiling
after that and it still didn't work.
Very odd.
I'll answer your questions for the record (and I have a question).
I clicked on the profiling icon in the toolbar. TPTP knows that the
application is a JUnit class.
> tested and worked.
> for you?
Please forgive my ignorance, but what is the "system variable"?
I forgot to mention in my original post that my Java environment is 64-bit
jdk1.6.0_04.
Steve Emmerson
Re: 4.5.1 IAC profiling failure: org.eclipse.tptp.jvmti unavailable: JPIBootLoader [message #136822 is a reply to message #136777] Mon, 06 October 2008 10:30 Go to previous messageGo to next message
Hi Steven,
Could you try the following:
1. shutdown Eclipse workbench.
2. run
to setup Agent Controller
3. run
plugins/org.eclipse.tptp.platform.ac.linux_em64t_4.4.1.v2008 08290100/agent_controller/bin/ACServer
to start an standalone Agent Controller.
4. if step 2 and 3 run without error, restart Eclipse workbench and run your
profile.
The system variable I was referring are those varilables configure in the
Agent Controller config file.
Eugene
news:32a9fd6c46608e087932bcc2f7dea4f7$1@www.eclipse.org...
> Hi Eugene,
> utilities).
> Very odd.
>> tested and worked.
>> for you?
> jdk1.6.0_04.
> Steve Emmerson
Re: 4.5.1 IAC profiling failure: org.eclipse.tptp.jvmti unavailable: JPIBootLoader [message #136928 is a reply to message #136822] Mon, 13 October 2008 18:29 Go to previous messageGo to next message
Eugene,
Sorry for not responding sooner. I thought this forum would email me.
> 2. run
The above appears sufficient to get profiling working.
Perhaps I didn't correctly test for profiling when I ran the script before.
Thanks for your help.
Steve Emmerson
Re: 4.5.1 IAC profiling failure: org.eclipse.tptp.jvmti unavailable: JPIBootLoader [message #136938 is a reply to message #136822] Mon, 13 October 2008 18:43 Go to previous messageGo to next message
Eugene,
I spoke too soon in my previous reply. Profiling is no longer working
even though it was working. Attempting to obtain "Execution Time
Analysis" on a JUnit unit-test results in the following error message:
No execution statistics is available for display.
Either you have no trace selected in the Profiling Monitor view or the
current selection does not contain execution statistic information.
Note:
This view is available only if the trace contains execution statistics. To
collect this type of information, on the Profile tab in the Launch
configuration, choose the Execution Time Analysis option.
I successfully executed SetConfig.sh.
Executing ACServer in its bin/ directory resulted in the following error
message:
/ACServer: error while loading shared libraries: libtptpUtils.so.4:
cannot open shared object file: No such file or directory
Help?
--Steve
Re: 4.5.1 IAC profiling failure: org.eclipse.tptp.jvmti unavailable: JPIBootLoader [message #136974 is a reply to message #136938] Tue, 14 October 2008 09:49 Go to previous messageGo to next message
Hi Steven,
Could you check to see if you have the file libtptpUtils.so under the bin
folder?
Also do you have permission for files in the IAC or AC folders?
Eugene
news:5449ebd7e28b6dcd2961511e382d8ce2$1@www.eclipse.org...
> Eugene,
> Note:
> message:
> /ACServer: error while loading shared libraries: libtptpUtils.so.4: cannot
> Help?
> --Steve
Re: 4.5.1 IAC profiling failure: org.eclipse.tptp.jvmti unavailable: JPIBootLoader [message #136986 is a reply to message #136974] Tue, 14 October 2008 09:50 Go to previous messageGo to next message
I missed one folder in my last posting. Please also check the lib folder for
libtptpUtils.so file.
"Eugene Chan" <ewchan@ca.ibm.com> wrote in message
news:gd288q$ikr$1@build.eclipse.org...
> Hi Steven,
> folder?
> Eugene
>> Eugene,
>> Note:
>> To collect this type of information, on the Profile tab in the Launch
>> message:
>> Help?
>> --Steve
Re: 4.5.1 IAC profiling failure: org.eclipse.tptp.jvmti unavailable: JPIBootLoader [message #137008 is a reply to message #136986] Tue, 14 October 2008 11:47 Go to previous messageGo to next message
Eugene,
Here's the information. Some of the lines are wrapped. The shared
library is in the "lib" subdirectory but not the "bin".
$ pwd
/home/steve/.eclipse/org.eclipse.platform_3.4.0_185596441/pl ugins/org.eclipse.tptp.platform.ac.linux_em64t_4.4.1.v200808 290100/agent_controller/lib
$ ls -lL libtptpUtils.so*
-rwxr-xr-x 1 steve ustaff 106523 2008-09-23 12:42 libtptpUtils.so
-rwxr-xr-x 1 steve ustaff 106523 2008-09-23 12:42 libtptpUtils.so.4
-rwxr-xr-x 1 steve ustaff 106523 2008-09-23 12:42 libtptpUtils.so.4.5.0
$ ls -l libtptpUtils.so*
lrwxrwxrwx 1 steve ustaff 17 2008-09-26 13:31 libtptpUtils.so ->
libtptpUtils.so.4
lrwxrwxrwx 1 steve ustaff 21 2008-09-26 13:31 libtptpUtils.so.4 ->
$ cd ../bin
$ pwd
/home/steve/.eclipse/org.eclipse.platform_3.4.0_185596441/pl ugins/org.eclipse.tptp.platform.ac.linux_em64t_4.4.1.v200808 290100/agent_controller/bin
ls: cannot access libtptpUtils.so*: No such file or directory
Executing the "bin/ACStart.sh" script appears to start the Agent
Controller (verified with ps(1)). Attempting to obtain an "Execution Time
Analysis" in a subsequently started Eclipse session fails, however, with
the same error message in the "Execution Statistics" tab: "No execution
statistics is available for display.".
Steve
Re: 4.5.1 IAC profiling failure: org.eclipse.tptp.jvmti unavailable: JPIBootLoader [message #137020 is a reply to message #137008] Tue, 14 October 2008 16:51 Go to previous messageGo to next message
Hi Steven,
Does the session failed with no data displayed only? or any error in console
view?
If the problem is about data not displayed in view, make sure the profiling
filter configuration is correctly set to include your target package.
Also try close the view and double click on the profiling analysis type in
the profiling monitor view to reopen the view for data refresh.
Eugene
news:78e66e0de0408db106ee8fc74925448f$1@www.eclipse.org...
> Eugene,
> $ pwd
> libtptpUtils.so.4
> $ cd ../bin
> $ pwd
> Steve
Re: 4.5.1 IAC profiling failure: org.eclipse.tptp.jvmti unavailable: JPIBootLoader [message #137077 is a reply to message #137020] Wed, 15 October 2008 12:10 Go to previous messageGo to next message
> view?
There are no error messages in the "Console" view.
The "Execution Statistics" tab in the profiling perspective has the error
message "No execution statistics is available for display. ...".
I'm using the default filter set for "Java Profiling", which doesn't
appear to exclude my classes.
The "Test Availability" button returns true for "Java Profiling".
That did it. Apparently, the profiling view doesn't automatically change
to the results of a successful profiling session. I did not know that.
Steve Emmerson
Re: 4.5.1 IAC profiling failure: org.eclipse.tptp.jvmti unavailable: JPIBootLoader [message #137148 is a reply to message #137077] Thu, 16 October 2008 09:12 Go to previous message
Yes. the view stays linked with the last opened resource. Unless you enabled
the 'Link with Viewer' button in the Profiling Monitor view that will auto
refresh the view with your selection in the Profiling Monitor view.
news:80747352ed13dd3c818ab75ab304a658$1@www.eclipse.org...
>> console view?
>> profiling filter configuration is correctly set to include your target
>> package.
>> in the profiling monitor view to reopen the view for data refresh.
> Steve Emmerson
Previous Topic:Empty Execution Flow, Call Tree
Next Topic:Trying to profile tomcat
Current Time: Sat May 25 06:03:39 EDT 2013
Powered by FUDForum. Page generated in 0.02153 seconds
