Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » call stack problems (retry)
call stack problems (retry) [message #136067] Tue, 23 September 2008 13:33 Go to next message
andrea is currently offline andrea
Hi Eugene,
thx for your help but unfortunately, it doesn't work.
I try to explain my setting: I have a class A in a package p. I setting
options I selected exe time analysis and in edit of java profiling JRE 1.5
or newer I setted "p*" in class column and "*" in method name, finally I
selected "include" in column Rule.
Once profiling is completed I select exe time analysis/open with/execution
statistics obtaing correctly every views except call stack. I can see
thread view, for instance, and expand every node but call stack view is
empty. Notice thate I open call stack view starting from main menu
windows/show view/other/call stack.
What is incorrect?
Thx again,
Andrea
Re: call stack problems (retry) [message #136099 is a reply to message #136067] Tue, 23 September 2008 15:20 Go to previous messageGo to next message
Santi Ontañón is currently offline Santi Ontañón
Not sure if I understand what you are saying. But if I understand you
properly the windows you are opening (Call Stack) is only meaningful
during debugging. I'm not sure what are you expecting to see there after
profiling, since the "call stack" only makes sense in the middle of an
execution.
Re: call stack problems (retry) [message #136144 is a reply to message #136099] Wed, 24 September 2008 02:19 Go to previous messageGo to next message
> execution.
this is a test...
(my previous replies haven't been attached, I'm going to search what
doesn't work)
andrea
Re: call stack problems (retry) [message #136153 is a reply to message #136099] Wed, 24 September 2008 04:24 Go to previous messageGo to next message
> execution.
Thx Santi,
your speech is surely correct, but is there a way to stop execution of
profiler? That is: can it be used as a debugger? Can we set any
breakpoints?
What I'm going to get is tracing all the statements executed starting from
the beginnig to the end of the procedure. This task is in some way
obtained, for instance, expanding every node in thread windows. What I
wish is a sequence of all theese method callings possibly with the line
number.
So, I thought call stack was a suitable way, but as you fairly say, maybe
it's rather a way to get informations in a kind of debug mode.
Is it possible collect informations about the whole callings of methods,
that is, a rearragging what I see in thread window?
thx again
Andrea
Re: call stack problems (retry) [message #136401 is a reply to message #136153] Fri, 26 September 2008 16:48 Go to previous messageGo to next message
Eugene Chan is currently offline Eugene Chan
Hi Andrea,
The Call Stack view is designed to be used with Thread Analysis view, Call
Stack view shows a call stack of a thread selected in Thread Analysis view.
It has nothing to do with Execution Statistics.
If you want to understand the execution flow of your application, consider
the Call Tree tab under the Execution Statistics view which shows you a tree
presentation of your application execution.
It is not recommend to use profiler and debugger together as the debug
process will give misleading performance data of your application.eg. in
time measurement.
Eugene
"andrea " <ascarpa@dsi.unive.it> wrote in message
news:6636fa8dd016d89b107ab782185bf767$1@www.eclipse.org...
> Santi Onta
Re: call stack problems (retry) [message #136458 is a reply to message #136401] Sat, 27 September 2008 01:14 Go to previous messageGo to next message
thx Eugene...
call tree tab contains all I want to know... But is there a way to see it
in a "customizable" manner? I try to explain better: is there a way to
capture informations contained in call tree table in order to arrange
them, for instance, as a plain text without expanding every node?
Thx again
Andrea
> Hi Andrea,
> time measurement.
> Eugene
>>> execution.
>> Thx Santi,
>> breakpoints?
>> number.
>> thx again
>> Andrea
Re: call stack problems (retry) [message #136468 is a reply to message #136458] Mon, 29 September 2008 09:18 Go to previous messageGo to next message
Hi Andrea,
Unfortunately, there is currently no report/export support on the call tree
nor the execution flow table view for your need. Please open a feature
request on TPTP bugzilla system
( https://bugs.eclipse.org/bugs/enter_bug.cgi?product=TPTP%20P rofiling) if
you would like to have this feature support considered in the next feature
release.
Eugene
news:badea0b86fe1a38b964cf08fa84d6c8e$1@www.eclipse.org...
> thx Eugene...
> Thx again
> Andrea
>> Hi Andrea,
>> Call Stack view shows a call stack of a thread selected in Thread
>> Analysis view. It has nothing to do with Execution Statistics.
>> consider the Call Tree tab under the Execution Statistics view which
>> shows you a tree presentation of your application execution.
>> time measurement.
>> Eugene
>>> Santi Onta
Re: call stack problems (retry) [message #136478 is a reply to message #136468] Mon, 29 September 2008 13:45 Go to previous message
Thx so much Eugene.
I'll send my request at address in your message.
Bye,
Andrea
Previous Topic:tracing execution
Next Topic:eclipse freezing while profiling
Current Time: Tue May 21 18:38:28 EDT 2013
Powered by FUDForum. Page generated in 0.02263 seconds
