| How to play register AGR macro inside JUnit tests ? [message #135432] |
Thu, 04 September 2008 11:42  |
Vincent MAHE Messages: 129 Registered: July 2009 |
Hello
Do someone try (and succeed) to execute previously recorded GUI actions
with AutomatedGUIRecorder inside a JUnit test?
The purpose:
I have some functional tests to run on Eclipse bundles
(http://openembedd.org/download) for verification of correct integration
of model editors, demo samples, launch actions,...
Actually, test are done manually:
File
-> New
-> Examples...
-> OpenEmbeDD demo
-> OpenEmbeDD basic demo
and verify the sample project has been created
What we are trying to do:
- register the previous GUI sequence with TPTP AGR in a file
"New_Demo_Example.testsuite"
- write a JUnit(4) test like that:
public class RunExampleTest {
public static UMLEditor editor;
@Before
public void resetExampleProject() throws Exception {
Utils.cleanProject();
// execute the GUI sequence
Utils.playBackAGR("New_Demo_Example.testsuite");
@Test
public void openUMLEditor() throws Exception {
// get the UML editor with the diagram given by the demo.
editor = (UMLEditor)IDE.openEditor(UiTools.getPage(),
Utils.getUmlDiagramFile());
editor.close(false);
Assert.assertTrue(editor != null);
As a matter of fact, such play needs to be executed into the current
workbench, as the test is ran into a dedicated Eclipse (launched for the
test).
I work on this feature since one month, with no succeeding strategy
despite the number I tried.
Cordialement
Vincent MAHÉ
Ingénieur Plate-forme OpenEmbeDD - http://openembedd.org
IRISA-INRIA, Campus de Beaulieu, 35042 Rennes cedex, France
Tél: +33 (0) 2 99 84 71 00, Fax: +33 (0) 2 99 84 71 71
| Re: How to play register AGR macro inside JUnit tests ? [message #135549 is a reply to message #135432] |
Fri, 05 September 2008 07:31   |
Paul Slauenwhite Messages: 970 Registered: July 2009 |
Hi Vincent,
Unfortunately, the current AGR test execution architecture requires a
new instance of Eclipse during each run. You can reuse a workspace but
there is no way to associated an AGR test execution with a live instance of
Eclipse.
You can run your AGR test from a JUnit test class by using the Java
adapter for test execution provided by the Automatable Services Framework
(ASF):
http://help.eclipse.org/ganymede/topic/org.eclipse.hyades.te st.doc.user/tasks/tlaunching-tests-from-scripts-and-applicat ions.htm
Paul
"Vincent Mahe" <vmahe@irisa.fr> wrote in message
news:g9ovln$gb6$1@build.eclipse.org...
> Hello
> The purpose:
> File
> -> New
> -> Examples...
> -> OpenEmbeDD demo
> @Before
> @Test
> test).
> Cordialement
> Vincent MAH
| Re: How to play register AGR macro inside JUnit tests ? [message #135574 is a reply to message #135549] |
Fri, 05 September 2008 07:52  |
Paul Slauenwhite a écrit :
> Hi Vincent,
> Eclipse.
The fact the recorder runs in the current workspace and the player
cannot is quite disconcerting :-(
> (ASF):
> Paul
I had a look on that, but it does not satisfy my requirements.
I am currently looking at SWTbot which seems exactly run like I need
(but with less features than AutoGUIRecorder).
>> Hello
>> The purpose:
>> File
>> -> New
>> -> Examples...
>> -> OpenEmbeDD demo
>> @Before
>> @Test
>> test).
>> Cordialement
>> Vincent MAHÉ
FUDForum. Page generated in 0.08940 seconds
