Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » java.exe crashes when profiling
java.exe crashes when profiling [message #134167] Fri, 08 August 2008 16:31 Go to next message
Eclipse User
Originally posted by: zozo.hp.com
I'm using:
WinXP SP2 on IA32
JRE 1.6.07
Eclipse 3.4
TPTP 4.5, Agent Controller 4.5
...and when I try to launch a profiling session, java.exe crashes. Here's
what I did:
- Verify project compiles/launches in Run mode
- Launch agent controller ACServer.exe
- Select main class and click Profile As Eclipse Application
- Select "Execution Time Analysis" monitor
I tried adding the -Djava.compiler=NONE flag as suggested in another
thread but it didn't work. I've also been able to verify the connection to
the ACServer (Test Availability in the Monitor tab) successfully.
Any suggestions?
Mike
Re: java.exe crashes when profiling [message #134235 is a reply to message #134167] Mon, 11 August 2008 07:24 Go to previous messageGo to next message
Asaf Yaffe is currently offline Asaf Yaffe
Mike,
Can you attach the Java crash log along with any other error message/log
you have?
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: java.exe crashes when profiling [message #134272 is a reply to message #134235] Mon, 11 August 2008 16:47 Go to previous messageGo to next message
Eclipse User
I don't have a Java crash log; it just dies with the system error
"java.exe has encountered a problem and needs to close."
Error signature:
AppVer 6.0.70.6
ModName ntdll.dll
ModVer 5.1.2600.2180
Offset 00011430
Exception code 0xc0000005 flags 0x00000000
Sorry, I know this isn't terribly helpful. Is there a way to get a more
useful log?
Mike
Re: java.exe crashes when profiling [message #135314 is a reply to message #134272] Sun, 31 August 2008 09:16 Go to previous message
Mike,
Please define the following environment variables at the *machine
level*, restart Eclipse, reproduce the crash and post the generated log
file here:
MARTINI_LOGGER_DIRECTORY=<full path to a directory of your choice>
MARTINI_LOGGER_LOG_LEVEL=5
Asaf
Asaf Yaffe
Previous Topic:TPTP and JNI
Next Topic:Profiling show no information when I use attach to an existing process method
Current Time: Sat May 25 09:57:49 EDT 2013
Powered by FUDForum. Page generated in 0.01823 seconds
