Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP and JNI
TPTP and JNI [message #135223] Fri, 29 August 2008 16:45 Go to next message
Mike Sacauskis is currently offline Mike SacauskisFriend
I'm getting a stack track when I try to profile will an app that uses a
JNI library. I can run the app in debug and no debug mode with out any
problem. Does TPTP handle jni?
Re: TPTP and JNI [message #135301 is a reply to message #135223] Sun, 31 August 2008 13:12 Go to previous message
Asaf Yaffe is currently offline Asaf YaffeFriend
Mike,
Can you provide more details about your problem? What are you trying to
do? Do you experience any error (what do you mean by "stack track"?)? If
yes, can you post the error?
Also, please provide the following information:
- OS version and architecture
- TPTP version
- Eclipse version
- Java version (use java -version to check)
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Previous Topic:blank Profiling Monitor view
Next Topic:java.exe crashes when profiling
Current Time: Sat Jul 22 09:07:15 GMT 2017
Powered by FUDForum. Page generated in 0.03785 seconds
