Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » blank Profiling Monitor view
blank Profiling Monitor view [message #135058] Tue, 26 August 2008 12:43 Go to next message
Nick Radov is currently offline Nick Radov
I am running Eclipse 3.4.0 (Build id: I20080617-2000), the latest versions
of all TPTP plug-ins from the update site, and Java 1.6.0_07 on MS Windows
XP. The Java performance profiling feature has suddenly stopped working.
The Profiling Monitor view is just blank and doesn't display any results.
No errors are displayed anywhere
I tried using the Reset Perspective menu item for the Profiling and
Logging perspective but that had no effect. I also tried deleting and
recreating the run configuration for the program I want to profile.
Is there any other way to troubleshoot this problem and determine why the
feature failed?
Re: blank Profiling Monitor view [message #135072 is a reply to message #135058] Tue, 26 August 2008 13:55 Go to previous messageGo to next message
Eugene Chan is currently offline Eugene Chan
Hi Nick,
Is there any log entry in the workspace/.metadata/.log file that maybe
related?
Could you try with the TPTP 4.5.0 all-in-one driver posted here >
http://www.eclipse.org/tptp/home/downloads/?ver=4.5.0
Eugene
"Nick Radov" <nradov@axolotl.com> wrote in message
news:45bfb5b8e937c0701d0a262b3a38ece5$1@www.eclipse.org...
> feature failed?
Re: blank Profiling Monitor view [message #135086 is a reply to message #135072] Tue, 26 August 2008 15:57 Go to previous messageGo to next message
There are indeed some TPTP errors in the .log file. Should I report this
as a bug?
!SESSION 2008-08-26 12:51:09.369
eclipse.buildId=I20080617-2000
java.version=1.6.0_07
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 2 0 2008-08-26 12:51:17.571
!MESSAGE Warnings while parsing the key bindings from the
'org.eclipse.ui.commands' extension point
!SUBENTRY 1 org.eclipse.ui 2 0 2008-08-26 12:51:17.571
!MESSAGE Cannot bind to an undefined command:
plug-in='org.eclipse.tm.terminal', id='org.eclipse.tm.terminal.command1'
!ENTRY org.eclipse.update.configurator 4 0 2008-08-26 12:51:50.506
!MESSAGE Can't find bundle for base name feature, locale en_US
!ENTRY org.eclipse.update.configurator 4 0 2008-08-26 12:51:52.974
!ENTRY org.eclipse.update.configurator 4 0 2008-08-26 12:51:53.709
!ENTRY org.eclipse.update.configurator 4 0 2008-08-26 12:51:54.537
!ENTRY org.eclipse.update.configurator 4 0 2008-08-26 12:51:55.740
!ENTRY org.eclipse.update.configurator 4 0 2008-08-26 12:51:57.052
!ENTRY org.eclipse.update.configurator 4 0 2008-08-26 12:52:00.052
!ENTRY org.eclipse.update.configurator 4 0 2008-08-26 12:52:00.442
!ENTRY org.eclipse.osgi 2 0 2008-08-26 12:52:06.551
!MESSAGE While loading class
"org.eclipse.hyades.trace.ui.internal.core.TraceUIImages", thread
"Thread[main,6,main]" timed out waiting (5000ms) for thread
"Thread[Worker-6,5,main]" to finish starting bundle
" reference:file:plugins\org.eclipse.hyades.trace.ui_4.4.101.v 200806130100.jar
[643]". To avoid deadlock, thread "Thread[main,6,main]" is proceeding but
"org.eclipse.hyades.trace.ui.internal.core.TraceUIImages" may not be fully
initialized.
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle
" reference:file:plugins\org.eclipse.hyades.trace.ui_4.4.101.v 200806130100.jar "
by thread "Worker-6".
org.eclipse.osgi.framework.internal.core.AbstractBundle.begi nStateChange(AbstractBundle.java:1144)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:263)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:368)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:444)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at org.eclipse.hyades.trace.ui.UIPlugin$1.run(UIPlugin.java:404 )
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
Caused by:
org.eclipse.osgi.framework.internal.core.AbstractBundle$Bund leStatusException
... 38 more
Root exception:
!ENTRY org.eclipse.core.resources 4 567 2008-08-26 12:52:49.875
!MESSAGE Failure occurred reading .project file.
!SUBENTRY 1 org.eclipse.core.resources 4 567 2008-08-26 12:52:49.875
!MESSAGE Could not read metadata for 'ProfileProject'.
!STACK 0
org.xml.sax.SAXParseException: Content is not allowed in prolog.
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. createSAXParseException(Unknown
Source)
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. fatalError(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.rep ortError(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFat alError(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$PrologDriver.next(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.next(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
org.eclipse.core.internal.resources.ProjectDescriptionReader .read(ProjectDescriptionReader.java:599)
org.eclipse.core.internal.localstore.FileSystemResourceManag er.read(FileSystemResourceManager.java:661)
org.eclipse.core.internal.resources.Project.updateDescriptio n(Project.java:1096)
at org.eclipse.core.internal.resources.Project.create(Project.j ava:273)
at org.eclipse.core.internal.resources.Project.create(Project.j ava:234)
at org.eclipse.core.internal.resources.Project.create(Project.j ava:227)
org.eclipse.tptp.platform.common.ui.trace.internal.util.PDCo reUtil.createContainer(PDCoreUtil.java:160)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.createModelEntities(TIDelegateHelper.java:1401 )
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.createModelEntities(TIDelegateHelper.java:1356 )
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.attachToAgent(TIDelegateHelper.java:713)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.attachToAgent(TIDelegateHelper.java:653)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.access$7(TIDelegateHelper.java:651)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper$2.processLaunched(TIDelegateHelper.java:492)
org.eclipse.tptp.platform.execution.client.core.internal.Pro cessImpl.launchAC(ProcessImpl.java:701)
org.eclipse.tptp.platform.execution.client.core.internal.Pro cessImpl.launch(ProcessImpl.java:130)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launchProcess(TIDelegateHelper.java:527)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launch(TIDelegateHelper.java:325)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TIJ avaLauncherDelegate.launch(TIJavaLauncherDelegate.java:37)
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.delegateInit(LauncherUtility.java:1164)
org.eclipse.tptp.trace.ui.provisional.launcher.PrimaryLaunch Delegate.run(PrimaryLaunchDelegate.java:195)
at java.lang.Thread.run(Unknown Source)
!SUBENTRY 1 org.eclipse.core.resources 2 567 2008-08-26 12:52:49.875
!STACK 0
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Re: blank Profiling Monitor view [message #135151 is a reply to message #135086] Wed, 27 August 2008 11:39 Go to previous message
Hi Nick,
It looks like your workbench or workspace is corrupted. Could you try with a
fresh install and workspace again?
Eugene
news:2e9e3f80a65a46e354fbf30fe814dde2$1@www.eclipse.org...
> as a bug?
> !SESSION 2008-08-26
> 12:51:09.369 -----------------------------------------------
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> initialized.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> ... 38 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:no http requests recorded
Next Topic:TPTP and JNI
Current Time: Fri May 24 17:25:57 EDT 2013
Powered by FUDForum. Page generated in 0.02847 seconds
