Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » TPTP unable to list shared network Drives
TPTP unable to list shared network Drives [message #133527] Tue, 29 July 2008 10:04 Go to next message
saran is currently offline saran
Hi All,
We have converted a junit test into tptp j unit test.
After the conversion we are not able to access the shared network drive
which we are able to access it using j unit.
String url = "H:\\hello.txt";
We tried the various other options like as follows
Still it fails
String url = "file:/H:/hello.txt";
String url = "\\\\cnwanx1_users_server\\users\\E11611\\hello.txt";
Is there is a seperate syntax that we need to use in TPTP to access files
from shared network Drive?
We are using Testing Tools Project , 4.3.200.v20070956
Please help with this.
Saran
Re: TPTP unable to list shared network Drives [message #133540 is a reply to message #133527] Tue, 29 July 2008 13:05 Go to previous message
Paul Slauenwhite is currently offline Paul Slauenwhite
Hi Saran,
Your JUnit test code should not have to change after converted to a TPTP
JUnit test. That said, relative paths may need to be changed when the TPTP
JUnit test is executed on a remote machine. Are you launching this locally
or remotely? Is there an exception?
Paul
"Saran" <saravanan.subramanian@cmegroup.com> wrote in message
news:6574b545d8dc46587eb7b8172063b3ea$1@www.eclipse.org...
> Hi All,
> Still it fails
> Thanks
> Saran
Previous Topic:AGR deployments and Ant
Next Topic:Freeze when click on "monitor" to configure run profile
Current Time: Wed May 22 15:40:47 EDT 2013
Powered by FUDForum. Page generated in 0.01819 seconds
