Home » Eclipse Projects » Orbit » Why is bundle org.apache.commons.discovery not provided as jar bundle instead of unpacked folder?
Why is bundle org.apache.commons.discovery not provided as jar bundle instead of unpacked folder? [message #13133] Thu, 19 June 2008 08:06 Go to next message
Eclipse User
Originally posted by: eclipse.shedid.de
Hello all,
we noticed that bundle org.apache.commons.discovery is not provided as
jared bundle. All other apache commons bundles can directly be used as
jars without the need to unpack them within an Eclipse installation.
Is there a special reason for this?
Kind regards,
Dirk
Re: Why is bundle org.apache.commons.discovery not provided as jar bundle instead of unpacked folder [message #13189 is a reply to message #13133] Fri, 20 June 2008 13:25 Go to previous message
David Williams is currently offline David Williams
I'd have to check, to know for sure for this case, but most cases like this were intentionally done,
by the "contributing project" simply because they had code that depended on it being done
that way, and they have't had time yet to change their consuming code (or, test for side effects, etc.).
If you have an urgent need, you could always open a bug (in orbit) and ... if really urgent ...
volunteer with the projects involved to see if they could use help in converting their code, or testing the jarred version. I think WTP (probably Webservices) is one of those projects. And ... this is a "2009" issue at this time (that is, not something that could change in a few weeks, or probably even months, given priorities).
Was that more than you wanted to know? :)
Re: Why is bundle org.apache.commons.discovery not provided as jar bundle instead of unpacked folder [message #563772 is a reply to message #13133] Fri, 20 June 2008 13:25 Go to previous message
Previous Topic:Why is bundle org.apache.commons.discovery not provided as jar bundle instead of unpacked folder?
Next Topic:Orbit update site?
Current Time: Sun May 19 18:53:14 EDT 2013
Powered by FUDForum. Page generated in 0.01878 seconds
