Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Using JET with EMF model
Using JET with EMF model [message #129811] Mon, 22 September 2008 09:42 Go to next message
Pavel Bernshtam is currently offline Pavel Bernshtam
Member
Hi!
I need to run JET templates on a EMF model metadata - i.e. the model
itself (not data) is input to my JET template.
More practically - I want generate non java code, based on EMF model.
How I do it?
Thank you
Re: Using JET with EMF model [message #129824 is a reply to message #129811] Mon, 22 September 2008 11:09 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Pavel,
The org.eclipse.emf.examples.generator.validator example would be good
to look at. Note that there's a JET newsgroup if you're using JET and
an EMF newsgroup. Of those two would be a better place to ask. I've
included both in the "to" list of the reply.
Pavel Bernshtam wrote:
> Hi!
> How I do it?
> Thank you
Re: Using JET with EMF model [message #129837 is a reply to message #129824] Mon, 22 September 2008 12:05 Go to previous messageGo to next message
Member
Thank you, where can I get this example source code?
Re: Using JET with EMF model [message #129850 is a reply to message #129837] Mon, 22 September 2008 12:41 Go to previous messageGo to next message
--------------090806070706080701020109
Pavel,
The examples are available with each download:
<http://www.eclipse.org/modeling/emf/downloads/?project=emf>
If you have the EMF SDK installed, you can install them in the workspace
via the wizards as well...
<html>
<head>
http-equiv="Content-Type">
</head>
Pavel,<br>
<br>
The examples are available with each download:<a
href="http://www.eclipse.org/modeling/emf/downloads/?project=emf"><br>
</a>
<blockquote><a
href="http://www.eclipse.org/modeling/emf/downloads/?project=emf">http://www.eclipse.org/modeling/emf/downloads/?project=emf</a><br>
</blockquote>
workspace via the wizards as well...<br>
<br>
<br>
<br>
<blockquote
cite="mid:d9d780f225998dbba5c45e8e3bd2ce8e$1@www.eclipse.org"
type="cite">Thank you, where can I get this example source code?
<br>
<br>
</blockquote>
</body>
</html>
--------------090806070706080701020109--
Re: Using JET with EMF model [message #129890 is a reply to message #129850] Thu, 25 September 2008 03:44 Go to previous messageGo to next message
Member
Thank you.
I'm very sorry for the my novice question - how I use these examples?
I see that they are packaged as a plugin - how I install and view them?
I tried to add only validator exaple as "Import project" but then he lost
all his dependencies
Re: Using JET with EMF model [message #129903 is a reply to message #129890] Thu, 25 September 2008 06:22 Go to previous messageGo to next message
Pavel,
That zip file has then in installable form, which isn't so useful if you
want to see them or import them into the workspace. I'm getting an
install of the modeling package to see where in the wizards the ability
to import the zipped examples packaged in the SDK hides, but that's kind
of slow at the moment because the SR1 just came out yesterday. I've
attached the example.psf file so you can use "File->Import->Team->Team
Project Set" and extract the example directly from CVS.
> Thank you.
> lost all his dependencies
Re: Using JET with EMF model [message #129978 is a reply to message #129903] Tue, 07 October 2008 04:11 Go to previous messageGo to next message
Member
Sorry, I do not see the attachment.
Can you send me it to pavelber at cadence dot com ?
Re: Using JET with EMF model [message #130002 is a reply to message #129978] Tue, 07 October 2008 06:55 Go to previous messageGo to next message
--------------090800070904080100030207
Pavel,
I think I forgot to attach it because I don't see it either. :-P
Content-Type: text/xml;
name="example.psf"
Content-Disposition: inline;
filename="example.psf"
<psf version="2.0">
<provider id="org.eclipse.team.cvs.core.cvsnature">
<project reference=" 1.0,:pserver:dev.eclipse.org:/cvsroot/modeling,org.eclipse.e mf/org.eclipse.emf/examples/org.eclipse.emf.examples.generat or.validator,org.eclipse.emf.examples.generator.validator "/>
</provider>
</psf>
--------------090800070904080100030207--
Re: Using JET with EMF model [message #130129 is a reply to message #129903] Sun, 12 October 2008 08:05 Go to previous messageGo to next message
Member
Which user/password should I use while accessing files directly from CVS?
Re: Using JET with EMF model [message #130142 is a reply to message #130129] Sun, 12 October 2008 08:47 Go to previous message
Kamesh Sampath is currently offline Kamesh Sampath
There is a reference for the same at
http://wiki.eclipse.org/index.php/CVS_Howto
Re: Using JET with EMF model [message #620320 is a reply to message #129811] Mon, 22 September 2008 11:09 Go to previous message
Pavel,
> Hi!
> How I do it?
> Thank you
Re: Using JET with EMF model [message #620321 is a reply to message #129824] Mon, 22 September 2008 12:05 Go to previous message
Member
Re: Using JET with EMF model [message #620322 is a reply to message #129837] Mon, 22 September 2008 12:41 Go to previous message
Pavel,
<html>
<head>
</head>
Pavel,<br>
<br>
</a>
<blockquote><a
</blockquote>
<br>
<br>
<br>
<blockquote
<br>
<br>
</blockquote>
</body>
</html>
Re: Using JET with EMF model [message #620325 is a reply to message #129850] Thu, 25 September 2008 03:44 Go to previous message
Member
Thank you.
Re: Using JET with EMF model [message #620326 is a reply to message #129890] Thu, 25 September 2008 06:22 Go to previous message
Pavel,
> Thank you.
Re: Using JET with EMF model [message #620332 is a reply to message #129903] Tue, 07 October 2008 04:11 Go to previous message
Member
Re: Using JET with EMF model [message #620334 is a reply to message #129978] Tue, 07 October 2008 06:55 Go to previous message
Pavel,
name="example.psf"
<psf version="2.0">
</provider>
</psf>
Re: Using JET with EMF model [message #620344 is a reply to message #129903] Sun, 12 October 2008 08:05 Go to previous message
Member
Re: Using JET with EMF model [message #620345 is a reply to message #130129] Sun, 12 October 2008 08:47 Go to previous message
Previous Topic:Code generation from ant or maven
Next Topic:[EMF Compare] Infos about the planned "patch/changeset model" feature?
Current Time: Sat May 18 16:22:14 EDT 2013
Powered by FUDForum. Page generated in 0.02287 seconds
