| Update Hook Adapter fragment [message #129783] |
Thu, 23 April 2009 03:31 |
Hugues Rérolle Messages: 60 Registered: July 2009 |
Member |
Hi all,
I've some problems with hook adapter.
I've instaled an osgi hook fragment in plugins directory :
plugins/my.osgi.hook_1.0.0.jar
I've put the following line in config.ini :
osgi.framework.extensions=my.osgi.hook
And it's worked fine !
But if I add an update of my fragment in plugins direcory, for example :
plugins/my.osgi.hook_1.0.1.jar, eclipse try to start (starts and stops,
Infinitely)
Same behaviour, if I remove the line in config.ini, or remove fragment
in plugins directory.
For start eclipse, I've to:
kill eclipse process
start in clean mode
restore the line in config.ini
and restart eclipse.
Anybody knows what's happen and how can I solve my problem ?
Thanks in advance
Hugues
Note: I want to use software update for update my application and hook
FUDForum. Page generated in 0.02302 seconds
