Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMF Compare] Infos about the planned "patch/changeset model" feature?
| Re: [EMF Compare] Infos about the planned "patch/changeset model" feature? [message #129589 is a reply to message #129585] |
Tue, 09 September 2008 09:17   |
Patrick Konemann Messages: 116 Registered: July 2009 |
Hi Cédric,
thank you for your reply.
I have already developed and implemented concepts for a model independent delta [1], but it was only specific for the meta model of the Enterprise Architect [2].
Now I would like to generalize it for arbitrary EMF models, probably based on an EMF Compare diffmodel.
Do you have any references to the work from Aquila University?
Patrick
[1] http://paphko.de/ea/ (Tool description and download)
http://web15.rom186.server4you.de/ea/Documents/Diplomarbeit. pdf (Master's thesis, in German)
[2] http://www.sparxsystems.com/
Cédric Brun wrote:
> Hi Patrick,
> The work on this feature is planned for the 1.0 release but did not start yet. The goal is to get a self contained and independent model capturing the changes and you might want to apply on another model (just as a patch in the text world).
> You should be able to apply this changeset even if the model changed in the meantime (once again, just as the text patchs and the "fuzzy mode").
> As we did not started yet, feel free to have a try on this feature with your solution, we could integrate it in the component. Right now we've only studied solutions designed by an Aquila University Phd candidate for such a model and the corresponding transformations to detect conflicts between changesets.
> Cédric
> Patrick Könemann wrote:
>> Hi developers,
>> I am curious - I read in the wiki [1] that a patch/changeset model is
>> planned for release 1.0. Is there more detailed information available?
>> Will such a changeset or patch model be independent of the (two) models it
>> was created from? (I am interested in it because I am working on something
>> similar) Thanks for any information!
>> [1] http://wiki.eclipse.org/EMF_Compare
>> Best regards
>> Patrick
| Re: [EMF Compare] Infos about the planned "patch/changeset model" feature? [message #129693 is a reply to message #129589] |
Tue, 16 September 2008 12:12   |
Hi all,
Just for anyone who is interested: I have set up a blog in which I will document my work on model-independent diffs. It already contains some of my thoughts. :)
http://paphko.de/diff
Best regards
Patrick
> Hi Cédric,
> Patrick
> Cédric Brun wrote:
>> Hi Patrick,
>> mode").
>> Cédric
>>> Hi developers,
>>> models it
>>> something
>>> Best regards
>>> Patrick
| Re: [EMF Compare] Infos about the planned "patch/changeset model" feature? [message #130147 is a reply to message #129693] |
Tue, 14 October 2008 04:25  |
Hi all,
The ideas for model-independent diffs are roughly complete.
Any comments are welcome ;-)
http://paphko.de/diff/metamodel.html
Cheers
Patrick
> Hi all,
> my thoughts. :)
> Best regards
> Patrick
>> Hi Cédric,
>> Patrick
>> Cédric Brun wrote:
>>> Hi Patrick,
>>> mode").
>>> Cédric
>>>> Hi developers,
>>>> models it
>>>> something
>>>> Best regards
>>>> Patrick
| Re: [EMF Compare] Infos about the planned "patch/changeset model" feature? [message #620303 is a reply to message #129578] |
Tue, 09 September 2008 08:38  |
Cedric Brun Messages: 329 Registered: July 2009 |
Hi Patrick,
Cédric
> Hi developers,
> Best regards
> Patrick
| Re: [EMF Compare] Infos about the planned "patch/changeset model" feature? [message #620304 is a reply to message #129585] |
Hi Cédric,
Patrick
Cédric Brun wrote:
> Hi Patrick,
> Cédric
>> Hi developers,
>> Best regards
>> Patrick
| Re: [EMF Compare] Infos about the planned "patch/changeset model" feature? [message #620310 is a reply to message #129589] |
Hi all,
Best regards
Patrick
> Hi Cédric,
> Patrick
> Cédric Brun wrote:
>> Hi Patrick,
>> mode").
>> Cédric
>>> Hi developers,
>>> models it
>>> something
>>> Best regards
>>> Patrick
| Re: [EMF Compare] Infos about the planned "patch/changeset model" feature? [message #620346 is a reply to message #129693] |
Hi all,
Cheers
Patrick
> Hi all,
> my thoughts. :)
> Best regards
> Patrick
>> Hi Cédric,
>> Patrick
>> Cédric Brun wrote:
>>> Hi Patrick,
>>> mode").
>>> Cédric
>>>> Hi developers,
>>>> models it
>>>> something
>>>> Best regards
>>>> Patrick
Current Time: Wed May 22 06:25:01 EDT 2013
Powered by FUDForum. Page generated in 0.02939 seconds
