Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Forms] TabFolder & MultiViews
[EMF Forms] TabFolder & MultiViews [message #1270583] Thu, 13 March 2014 07:11 Go to next message
Goulwen Le Fur is currently offline Goulwen Le FurFriend
I found no information on how to declare a TabFolder in EMF Forms. Is there any way to achieve this ?
I have a second question, what is the viewmodel choice policy when several viewmodels describe a form for the same EClass ?
[Updated on: Thu, 13 March 2014 07:18]
Report message to a moderator
Re: [EMF Forms] TabFolder & MultiViews [message #1270630 is a reply to message #1270583] Thu, 13 March 2014 08:50 Go to previous messageGo to next message
Jonas Helming is currently offline Jonas HelmingFriend
Hi Goulwen,
we have tab folder in several projects by replacing the category
renderer. Although this alternative renderer is currently not in the OS
project. If you need it, please file a BR.
Second: If you register the view models using the extension point, there
should be only one. But as the renderer also allows to manually specify
the view model to be used, you can use any condition you want.
Best regards
Jonas
Am 13.03.2014 08:11, schrieb Goulwen Le Fur:
> I have a second question, what is the viewmodel choice policy when many
> viewmodel describes a form for the same EClass ?
> Thanks
Re: [EMF Forms] TabFolder & MultiViews [message #1270637 is a reply to message #1270630] Thu, 13 March 2014 08:58 Go to previous messageGo to next message
Thanks Jonas for the reply,
Is there any service provided by EMF Forms to access to all registered ViewModel referencing a given EClass ?
Re: [EMF Forms] TabFolder & MultiViews [message #1271118 is a reply to message #1270637] Fri, 14 March 2014 10:09 Go to previous message
if you mean registered via the extension point then you can use this:
ViewModelFileExtensionsManager
However, it is currently not API.
Cheers
Jonas
Am 13.03.2014 09:58, schrieb Goulwen Le Fur:
Previous Topic:EGF Run new activity ...
Next Topic:[EMF Forms] Performance problems while switching between opened views
Current Time: Sat Jul 22 08:58:07 GMT 2017
Powered by FUDForum. Page generated in 0.08339 seconds
