| Porting issue. The Second step. [message #126587] |
Mon, 17 March 2008 10:52  |
Originally posted by: ck2329.mail.ru
I'm happy to say that now Eclipse is able to show some info from my
target(linux mips) -heap and gc profilers are partitially in working state.
But anyway tptp is still extremely unstable.
Issue list:
1) It is impossible to connect threadProf - it fails on registering
MonitorWait event, MonitorWaited event etc capabilities on the JVM.
2) It is impossible to "attach to agent" from the first attempt - first i
should attach(i checked fileter - it is empy and named as "Default") -
then Detach from Agent - then attach again(now filter will be not empty
and named as "__JVMPI__" )
3) After first succesfull connecting to jvmti agent(server=enabled;
HeapProf) through AC and then stopping profiling session - it is
impossible to connect one more time.
4) If i choose "Run GC" then jvmti agent causes Segmentation fault
5) If i choose terminate process - then agent receives Kill signal - but
AC is already dead because of segmentation fault.
Please give some comments to the mentioned above if possible.
| Re: Porting issue. The Second step. [message #126878 is a reply to message #126866] |
Wed, 19 March 2008 05:42   |
Asaf Yaffe wrote:
>> Issue list:
> Can you provide more information? Does it fail when invoking JVMTI
> SetEventNotificationMode? If so, what is the returned error code? If
> not, where does it fail?
> What JVM are you targeting (use 'java -version' on the target MIPS machine)?
It fails in CJVMTIInterface::RegisterEvent when calls to
m_pJVMTIInterface->AddCapabilities. return code is 98 - which means -
not_available. now im using latest cvm (rev62). Now im trying to
understand if cvm really doesnt support this event or something is wrong
with my request from martini side.
>> i should attach(i checked fileter - it is empy and named as "Default") -
> Can you provide more information? What do you mean by "first attempt"?
> Where does it fail? Is this an Agent Controller issue? Agent issue?
> Martini issue?
As i said to get some results in Eclipse i should attach to agent[FIRST
ATTEMPT] - then Detach from Agent - then attach again[SECOND ATTEMPT].
Actully there is no failure on first attempt - i just cannot get any info
in eclipse. I tried both with server = enabled and controlled
> Again, more information will be helpful (see previous question).
Current situation is a little bit different - i can connect - but
application seems to be frozen . according to your previous explanation i
applied patch https://bugs.eclipse.org/bugs/show_bug.cgi?id=186080 but it
works only for the first attach.
> Can you provide a stack dump (preferably in debug mode)? If not, can you
> point to the module causing the crash?
> Again... stack dump...
Now on going
> We'll do our best :)
I see! Thanks for your suport, i'll try to help you - if i know the answer
for other user's quetion - i'll reply!
One more question - how can i get latest (4.5) sources - is it HEAD
revision on main repository or you have dedicated one ?
| Re: Porting issue. The Second step. [message #126918 is a reply to message #126904] |
Wed, 19 March 2008 09:45   |
Thanks . You are right prroblem was caused by can_get_monitor_info. I
turned it on on my JVM - no ThreadProfiler works.
I chacked threadProf on my sample app. And results are confusing. My app
is running very very slow with tptp profiler.I tried to run NetBeans
profiler on the same target - it is more then 10 times faster :-(.
Probably i can make tptp faster by specifiyng some kind of filter? Now i
use just default settings. Can i ?
| Re: Porting issue. The Second step. [message #127027 is a reply to message #126968] |
Thu, 20 March 2008 02:50   |
I would like to perform following experiment:
I want to turn off all data transfer and check execution time in case of
internal (jvmti profiler) operations. What function should i stub for this?
Some more explanations - i want to leave only martini and some more
internal processing for JVM events. I want to exclude all XML related
operations. I need i t do determine if the great overhead is brought only
by XML or if some other(intenal) parts also bring some perfomance bottle
necks.
| Re: Porting issue. The Second step. [message #127166 is a reply to message #127153] |
Fri, 21 March 2008 05:16   |
Hi Igor
Unfortunately standalone mode is not suitable for our puprpose.
I already made stubs in PrintXML file - according to my rough measurment
on Windows system this doesnt provide significant speed up.
I got follwoing results with thread profiler in standalone mode(just for
test):
without profiling - 4.1 sec
with profiling and xml output - 8.2 sec
with profiling and with stubs in printxml - 7.9
Thats it. I also try to test on our target system asap.
Anyway imho TPTP uses too complicated profiling chain - Eclipse - AC -
profiler - JPI - Martini - JVM ....
| Re: Porting issue. The Second step. [message #127234 is a reply to message #127191] |
Mon, 24 March 2008 07:02  |
Asaf Yaffe Messages: 333 Registered: July 2009 |
Andrew V. Novoselsky wrote:
> Initialization stage time is excluded from my results.
What version of ThreadProf are you using? Is it the latest 4.5 code that
uses instrumentation for contention analysis, or the 4.4 code that does
not use instrumentation at all?
What is the amount of data created? Can you count the number of events
you get in your test scenarios?
In ThreadProf 4.4, we rely on JVMTI to provide all information and we do
not use instrumentation. For workloads which do not exhibit high monitor
contention, the overhead of the Martini layer itself should not be more
than 20-50%.
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
FUDForum. Page generated in 0.02456 seconds
