Home » Archived » COSMOS » Instance Id Constraint and record type constraint in same template,not possible?
Instance Id Constraint and record type constraint in same template,not possible? [message #12573] Thu, 19 February 2009 09:01 Go to next message
arunachalam is currently offline arunachalam
Hi ,
I am not able to run the query when I am having the instance id
constraint , record type constraint with in a same template. when I am
running the following query file ,
<query xmlns="http://cmdbf.org/schema/1-0-0/datamodel">
<itemTemplate id="template2">
<instanceIdConstraint>
<instanceId>
<mdrId>CCMDBMDR</mdrId>
<localId>Server1</localId>
</instanceId>
</instanceIdConstraint>
<recordConstraint>
<recordType localName="OS" namespace=""/>
</recordConstraint>
</itemTemplate>
</query>
I am getting the following exception.
Exception in thread "main" java.lang.NullPointerException
com.ibm.cmdbf.query.CMDBfQueryOperation.applyItemConstraints (CMDBfQueryOperation.java:485)
com.ibm.cmdbf.query.CMDBfQueryOperation.processItemTemplates (CMDBfQueryOperation.java:216)
com.ibm.cmdbf.query.CMDBfQueryOperation.execute(CMDBfQueryOp eration.java:139)
com.ibm.cmdbf.query.CMDBfQueryOperation.execute(CMDBfQueryOp eration.java:126)
at com.ibm.cmdbf.query.QueryLauncher.getResponse(QueryLauncher. java:93)
at com.ibm.cmdbf.query.QueryLauncher.main(QueryLauncher.java:64 )
I am getting the error on the applyItemConstraints method , Logically it
is wrong to have the instance id constraint record constraint with in the
same template , but the api is just throwing the null pointer exception.
Is this not possible to have the instance id constraint and record
constraint with in the same template ?
if this is not possible the API should inform the user by throwing the
custom exception something like "it is not possible to have the instance
id constraint and record constraint with in the same template"
Arunachalam.
Re: Instance Id Constraint and record type constraint in same template,not possible? [message #12593 is a reply to message #12573] Thu, 19 February 2009 19:15 Go to previous message
Eclipse User
Originally posted by: david_whiteman.us.ibm.com
Please create a bug report for this in bugzilla.
Thanks!
David
arunachalam wrote:
> Hi ,
> <instanceId>
> </instanceId>
> <recordConstraint>
> </recordConstraint>
> </itemTemplate>
> </query>
> at
> at
> at
> at
> Logically it is wrong to have the instance id constraint record
> constraint with in the same template , but the api is just throwing the
> the custom exception something like "it is not possible to have the
> instance id constraint and record constraint with in the same template"
> Regards
> Arunachalam.
Re: Instance Id Constraint and record type constraint in same template,not possible? [message #572516 is a reply to message #12573] Thu, 19 February 2009 19:15 Go to previous message
David Whiteman is currently offline David Whiteman
Thanks!
David
arunachalam wrote:
> Hi ,
> <instanceId>
> </instanceId>
> <recordConstraint>
> </recordConstraint>
> </itemTemplate>
> </query>
> at
> at
> at
> at
> Regards
> Arunachalam.
Previous Topic:Instance Id Constraint and record type constraint in same template,not possible?
Next Topic:COSMOS V1.1M1 is now available
Current Time: Sun May 19 13:01:11 EDT 2013
Powered by FUDForum. Page generated in 0.01938 seconds
