Home » Eclipse Projects » Remote Application Platform (RAP) » Busy Indicator not updated correctly in IE10
Busy Indicator not updated correctly in IE10 [message #1255347] Mon, 24 February 2014 10:45 Go to next message
Tiburon T is currently offline Tiburon TFriend
Member
we have noticed in our RAP application, that the busy indicator is sometimes not updated correctly. The mouse curser seems to change only after it was moved. For example if the user starts a long running operation by the press of a button, the cursor does not change its appearance before it is moved. The same happens when the processing is done, i.e. the cursor stays busy until moved again. This is sometimes irretating for the user in our application and we would like to fix it somehow. The problem does not occur in Firefox 24.3.0 so I guess it is a compatibility issue with IE...
A button like this will demonstrate the issue:
        Button b = new Button(container, SWT.PUSH);
        b.setText("test");
        b.addListener(SWT.Selection, new Listener()
            private static final long serialVersionUID = 1L;
            public void handleEvent(Event event)
                System.out.println("pressed");
                try {
                    Thread.sleep(3000);
                } catch (InterruptedException e) {
                    e.printStackTrace();
                System.out.println("finished");
Any help would be appreciated!
Tibu
Re: Busy Indicator not updated correctly in IE10 [message #1256227 is a reply to message #1255347] Tue, 25 February 2014 08:08 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi Tibu,
it's not a good idea to execute a long running operation in the UI
thread. Blocking the UI for a long time leads to bad user experience.
About your actual question - I can reproduce the issue with your snippet
in IE10/IE11/Chrome. Working fine in Firefox and Opera. Please file a
bugzilla and we will look on it.
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Busy Indicator not updated correctly in IE10 [message #1256234 is a reply to message #1256227] Tue, 25 February 2014 08:19 Go to previous message
Member
Thank you for your fast feedback. I filed the bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=428971
Greetings, Tibu
Previous Topic:EclipsVirgo Nano and RAP
Next Topic:Sash with inner Buttons
Current Time: Sat Jul 22 09:19:39 GMT 2017
Powered by FUDForum. Page generated in 0.03089 seconds
