Home » Eclipse Projects » Mylyn » How does the Alt+click work?
How does the Alt+click work? [message #12481] Fri, 13 July 2007 14:34 Go to next message
Eclipse User
Originally posted by: xiaoyang.guan.gmail.com
In the structured views with "focus on active task" turned on, I suppose
Alt+click on an element will reveal all its uninteresting children.
But when I do that, nothing happened except that the mouse icon turned
into a "+" sign. Alt+Right arrow works as expected, although I found
that just pressing Right Arrow itself also does the same if the view is
wide enough.
Is there any configuration in Preference in order to make Alt+click
work? BTW, I'm on a Linux machine (Ubuntu 6.06) if it's relevant.
Xiaoyang
Re: How does the Alt+click work? [message #12586 is a reply to message #12481] Fri, 13 July 2007 15:07 Go to previous messageGo to next message
Eclipse User
Originally posted by: beatmik.acm.org
Xiaoyang Guan wrote:
> Alt+click on an element will reveal all its uninteresting children. But
> when I do that, nothing happened except that the mouse icon turned into
> a "+" sign. Alt+Right arrow works as expected, although I found that
> just pressing Right Arrow itself also does the same if the view is wide
> enough.
A short explanation of how it works is here:
http://www.eclipse.org/mylyn/tips/
And a longer one here:
http://wiki.eclipse.org/index.php/Mylyn_User_Guide#Alt.2BCli ck_navigation
Mik
Re: How does the Alt+click work? [message #14061 is a reply to message #12586] Mon, 16 July 2007 15:01 Go to previous messageGo to next message
Eclipse User
>> suppose Alt+click on an element will reveal all its uninteresting
>> children. But when I do that, nothing happened except that the mouse
>> icon turned into a "+" sign. Alt+Right arrow works as expected,
>> although I found that just pressing Right Arrow itself also does the
>> same if the view is wide enough.
> Mik
Thanks Mik.
Follow-up: the problem I had was because the window manager uses
Alt+click for moving a window. Setting the window movement key to
something else makes Alt+click navigation in Mylyn work as expected.
Re: How does the Alt+click work? [message #14143 is a reply to message #14061] Tue, 17 July 2007 00:37 Go to previous messageGo to next message
Eclipse User
Thanks for following up Xiaoyang. The work-around should be described here:
http://wiki.eclipse.org/index.php/Mylyn_User_Guide#Installin g_on_Linux
If there's anything lacking it would be great if you could update that
entry.
Mik
Re: How does the Alt+click work? [message #14160 is a reply to message #14143] Tue, 17 July 2007 06:23 Go to previous message
Jörg Thönnes is currently offline Jörg Thönnes
> here:
More specifically (I wrote that entry ;-) ) here:
http://wiki.eclipse.org/index.php/Mylyn_User_Guide#Keyboard_ mappings_on_Linux>
Please consider voting on the Eclipse bug
#55236: Please support SWT.MOD4 on platforms other than the Mac
It is about adding Meta key support to Eclipse (for Linux).
Cheers, Jörg
Re: How does the Alt+click work? [message #571835 is a reply to message #12481] Fri, 13 July 2007 15:07 Go to previous message
Mik Kersten is currently offline Mik Kersten
> enough.
Mik
Re: How does the Alt+click work? [message #572363 is a reply to message #12586] Mon, 16 July 2007 15:01 Go to previous message
Xiaoyang Guan is currently offline Xiaoyang Guan
> Mik
Thanks Mik.
Re: How does the Alt+click work? [message #572594 is a reply to message #14061] Tue, 17 July 2007 00:37 Go to previous message
entry.
Mik
Re: How does the Alt+click work? [message #572614 is a reply to message #14143] Tue, 17 July 2007 06:23 Go to previous message
> here:
Cheers, Jörg
Previous Topic:bug hyperlinking in source?
Next Topic:Question regarding saved context
Current Time: Sat May 25 20:42:57 EDT 2013
Powered by FUDForum. Page generated in 0.04176 seconds
