| TPTP 4.4.1 standalone AC use works for HeapProf, but not GCProf [message #124673] |
Thu, 28 February 2008 04:52  |
David Wynter Messages: 4507 Registered: July 2009 |
With the help of Assaf Yaffe I got the agent controller standalone from
TPTP 4.4.1 running HeapProf. GCProf does not run. The only change I make
is replace the HeapProf argument at the end of the -agentlib:..... java
option passed to Tomcat at start up with the GCProf argument.
When it fails it outputs this in the command window
[Error: EC JPIAgent received message (FATAL ERROR): Internal error (see
log file).]
The trace log file is the only one I can find. It has these contents:
<?xml version="1.0"?>
<TRACE>
<node nodeId="" hostname="localhost" ipaddress="127.0.0.1" timezone="0"
time="1204191901.950000000"/>
<processCreate processId="b18e4b2a-9ac8-4a7b-bba4-7156ef452f6c"
pid="896" nodeIdRef="" time="1204191901.950000000"/>
<agentCreate agentId="122c126d-db2c-433b-b6c8-ef6e7030278f"
version="2.000" processIdRef="b18e4b2a-9ac8-4a7b-bba4-7156ef452f6c"
agentName="org.eclipse.tptp.jvmti" agentType="Profiler"
agentParameters="server=standalone,filters=filters.txt"
time="1204191901.981000000"/>
<traceStart traceId="14ce1a3e-8a4f-43f9-8b11-87c04eb9d58e"
agentIdRef="122c126d-db2c-433b-b6c8-ef6e7030278f"
time="1204191901.982531026"/>
<filter pattern="com.company.tran." mode="INCLUDE"
genericPattern="SUFFIX" methodPattern="" methodMode="INCLUDE"
methodGenericPattern="PREFIX"/>
<filter pattern="java.sql." mode="INCLUDE" genericPattern="SUFFIX"
methodPattern="" methodMode="INCLUDE" methodGenericPattern="PREFIX"/>
<filter pattern="" mode="EXCLUDE" genericPattern="PREFIX"
methodPattern="" methodMode="EXCLUDE" methodGenericPattern="PREFIX"/>
<option key="FILTERS" value="true"/>
<option key="OPTIONS" value="true"/>
<option key="STACK_INFORMATION" value="normal"/>
<option key="TICKET" value="true"/>
<option key="TIMESTAMPS" value="true"/>
<option key="TRACE_IDREFS" value="false"/>
<option key="CPU_TIME" value="false"/>
Ideas?
Thx.
David
| Re: TPTP 4.4.1 standalone AC use works for HeapProf, but not GCProf [message #130263 is a reply to message #124790] |
Sun, 18 May 2008 20:26   |
Originally posted by: greg.chrystall.co.nz
I am having the same problem mentioned. If i run JBoss with:
-agentlib:JPIBootLoader=JPIAgent:server=enabled;HeapProf
Everything works as expected and I can Profile the app in eclipse.
But when I run with:
-agentlib:JPIBootLoader=JPIAgent:server=enabled;GCProf
It dies with the following:
log file).]
Full JBoss output:
JBoss Bootstrap Environment
JBOSS_HOME: /opt/jboss/jboss-4.2.2.GA
JAVA: java
JAVA_OPTS: -Dprogram.name=run.sh -server -Xms128m -Xmx512m
-Dsun.rmi.dgc.client.gcInterval=3600000
-Dsun.rmi.dgc.server.gcInterval=3600000
-Djava.net.preferIPv4Stack=true
CLASSPATH: /opt/jboss/jboss-4.2.2.GA/bin/run.jar
log file).]
Any help on how to get GCProf working would be much appreciated.
Greg
david wrote:
> Ignore this. I need to spell things more accurately in future
> david wrote:
>> log file).]
>> <TRACE>
>> Ideas?
>> Thx.
>> David
| Re: TPTP 4.4.1 standalone AC use works for HeapProf, but not GCProf [message #130276 is a reply to message #130263] |
Sun, 18 May 2008 21:23   |
This is a simple case of dyslexia, changing GCProf to CGProf solved my
problems.
> log file).]
> Full JBoss output:
> JAVA: java
> log file).]
> Greg
>> david wrote:
>>> Hi,
>>> log file).]
>>> <TRACE>
>>> Ideas?
>>> Thx.
>>> David
FUDForum. Page generated in 0.01819 seconds
