| Obtaining data from HTTP response in URL tests [message #122567] |
Fri, 08 February 2008 13:26  |
Robert Enyedi Messages: 68 Registered: July 2009 |
Member |
I used the HTTP Recorder from TPTP 4.4.0.3 to create a TPTP URL Test.
The first request is to a login page. The tested application then
generates a unique SID, which is embedded in the response and all
subsequent requests are supposed to use it. This is like a custom SID
instead of JSESSIONID.
I need to obtain this generated SID and use it in the next requests. Is
there a way to do it (even by manual intervention over the generated
JUnit test code)?
Robert
FUDForum. Page generated in 0.01690 seconds
