| ArrayIndexOutofBoundsException [message #121590] |
Wed, 30 January 2008 20:59  |
Pushparaj Messages: 62 Registered: July 2009 |
Member |
Hi All,
I am trying to get familiar with TPTP's Automated GUI Recorder. During
these investigations I have problems while running my recorded test cases.
org.eclipse.core.runtime.CoreException
Error while executing a macro command: MacroCommand [choice-select, line
34]
java.lang.ArrayIndexOutOfBoundsException: 0
org.eclipse.tptp.test.auto.gui.internal.commands.ChoiceSelec tionCommand.playback(ChoiceSelectionCommand.java:143)
My recorded macro is,
<macro version="1.0">
<shell descriptive="OpenClovis IDE - ProjectCreationTestSuite -
Eclips..." referenceId="0" return-code="-1">
<command descriptive="Project..." type="select" referenceId="4"/>
<shell descriptive="New Project" referenceId="2" return-code="0">
<command descriptive="New Project" type="item-select" referenceId="5">
<item referenceId="13"/>
</command>
<command type="focus" referenceId="5"/>
<command descriptive="Next &gt;" type="select" referenceId="8"/>
<command type="modify" referenceId="9">
<![CDATA[Test]]>
</command>
<command type="modify" referenceId="22">
<![CDATA[/home/my/pkg]]>
</command>
<command type="modify" referenceId="15">
</command>
<![CDATA[/usr/bin]]>
</command>
<command descriptive="Add" type="select" referenceId="16"/>
<command descriptive="Add" type="select" referenceId="17"/>
<command descriptive="Add" type="select" referenceId="18"/>
<command descriptive="Node0" type="item-select" referenceId="19">
<item referenceId="20"/>
</command>
<command descriptive="Node1" type="choice-select" referenceId="21"
choiceId="item#1"/>
<command descriptive="Finish" type="select" referenceId="11"/>
</shell>
</shell>
</macro>
Pushparaj
| Re: ArrayIndexOutofBoundsException [message #121605 is a reply to message #121590] |
Thu, 31 January 2008 08:46   |
Jimmy Jin Messages: 32 Registered: July 2009 |
Member |
I guess you are using AGR version 4.3.x or earlier, right? Because as I
see in latest version (4.4.x), this error message will be shown
correctly as "Cannot locate view control: ...".
Your line 34 is
"<command descriptive="Node1" type="choice-select" referenceId="21"
choiceId="item#1"/>". So I think it cannot find the widget (with
referenceId 21). I suggest you do the steps manually in the EXACT
environment where you playback your script to see what the difference
is. There may be sometime that when you recording the script, some
widget is there, but when you playback, due to some environment
difference (such as number of project in workspace), something can be
different.
Jimmy Jin
Pushparaj wrote:
> Hi All,
> 34]
> at
> referenceId="5">
> </command>
> referenceId="8"/>
> <![CDATA[Test]]>
> </command>
> </command>
> </command>
> </command>
> referenceId="8"/>
> referenceId="8"/>
> referenceId="8"/>
> referenceId="19">
> </command>
> referenceId="21" choiceId="item#1"/>
> </shell>
> </shell>
> </macro>
> Pushparaj
| Re: ArrayIndexOutofBoundsException [message #122183 is a reply to message #121823] |
Tue, 05 February 2008 07:59  |
Member |
Hi Jimmy Jin,
I am using Eclips 3.2.1 and tptp 4.3.0
I think it is not able to find the items which are displayed in the
CCombo. Becuase i can able to playback the script if i didn't select the
item in. It is giving error only if i select the item in CCombo.
Note: Items which are displayed in the CCombo is captured in the previous
page.
Pushparaj.
FUDForum. Page generated in 0.05148 seconds
