Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » TPTP closes eclipse
TPTP closes eclipse [message #118286] Thu, 15 November 2007 11:29 Go to next message
Eclipse User
Originally posted by: david.coales.accipia.com
I have downloaded the tptp.runtime.allInOne.win32.win32.x86-TPTP-4.4.0 and
then opened eclipse. If I go to windows->preferences->profiling and
Logging->Hosts
select localhost:10002 and hit Test Connection then, after a brief pause,
Eclipse simply exits completely with no warning or preamble.
I have tried following the installation instructions and loading all the
recommended components by hand but get the same effect.
If I try to go to the Monitor pane in the profile dialog the same thing
happens.
Are there some other installation instructions that I should be following.
I'm only trying to run tests locally so I don't think I need the agent
controller.
I am running on windows vista with jre1.5.0_06. Any help would be much
appreciated.
Many thanks,
David
Re: TPTP closes eclipse [message #118296 is a reply to message #118286] Thu, 15 November 2007 11:44 Go to previous messageGo to next message
Eclipse User
Originally posted by: mauro.molinari.cardinis.com
> and then opened eclipse. If I go to windows->preferences->profiling and
> Logging->Hosts select localhost:10002 and hit Test Connection then,
> after a brief pause, Eclipse simply exits completely with no warning or
> preamble.
Try to have a look to .log file in <workspace-dir>\.metadata folder.
Mauro.
Re: TPTP closes eclipse [message #118314 is a reply to message #118286] Fri, 16 November 2007 02:07 Go to previous messageGo to next message
Igor Alelekov is currently offline Igor Alelekov
Hi David,
Try yo use any last TPTP 4.5 build instead of 4.4.0.
Also it might be usefull to install Eclipse without spaces in
%ECLIPSE_HOME% directoty.
Igor
Re: TPTP closes eclipse [message #118525 is a reply to message #118296] Wed, 21 November 2007 04:58 Go to previous message
Eclipse User
I tried reinstalling everything from scratch with eclipse in the directory
c:\eclipse (i.e. no spaces in the name as suggested in the other post) and
this time eclipse does not hang but the profiler still doesn't start. I
get the following message in the log file:
!SESSION 2007-11-21 09:55:04.187
eclipse.buildId=I20070625-1500
java.version=1.5.0_11
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.update.configurator 2007-11-21 09:55:22.744
!MESSAGE Can't find bundle for base name feature, locale en_GB
!ENTRY org.eclipse.update.configurator 2007-11-21 09:55:22.760
!ENTRY org.eclipse.update.configurator 2007-11-21 09:55:22.853
!ENTRY org.eclipse.update.configurator 2007-11-21 09:55:22.869
!ENTRY org.eclipse.update.configurator 2007-11-21 09:55:22.916
!ENTRY org.eclipse.update.configurator 2007-11-21 09:55:22.931
!ENTRY org.eclipse.hyades.trace.ui 4 4 2007-11-21 09:55:37.387
!MESSAGE A time-out occurred while attempting to launch the process
!STACK 1
org.eclipse.core.runtime.CoreException: A time-out occurred while
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:123)
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:131)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.handleError(TIDelegateHelper.java:596)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launchProcess(TIDelegateHelper.java:512)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launch(TIDelegateHelper.java:312)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TIJ UnitLauncherDelegate.launch(TIJUnitLauncherDelegate.java:33)
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.delegateInit(LauncherUtility.java:1153)
org.eclipse.tptp.trace.ui.provisional.launcher.PrimaryLaunch Delegate.run(PrimaryLaunchDelegate.java:196)
at java.lang.Thread.run(Unknown Source)
!SUBENTRY 1 org.eclipse.hyades.trace.ui 4 0 2007-11-21 09:55:37.387
Previous Topic:Cannot collect object references
Next Topic:Logging in AGR
Current Time: Sat May 25 22:07:23 EDT 2013
Powered by FUDForum. Page generated in 0.03630 seconds
