Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » IWAT4039E The Test Execution Harness reported the following problems:Failed to retrieve the context
IWAT4039E The Test Execution Harness reported the following problems:Failed to retrieve the context [message #117665] Fri, 09 November 2007 03:15 Go to next message
Eclipse User
Originally posted by: bmf1972.fastmail.fm
I have TPTP running, but at some point, perhaps after few updates, it
stoped. I can see a new Java process spawned by the
tptpProcessController.exe process but the execution stops with this
exception:
problems:Failed to retrieve the context that should be used to run the
test cases in
An exception stack trace is not available.
eclipse.buildId=I20070625-1500
java.version=1.6.0_02
Command-line arguments: -os win32 -ws win32 -arch x86
Here are my current configuration details:
*** Date: Friday, November 9, 2007 10:11:18 AM Israel
*** Platform Details:
*** System properties:
ANTLR_DO_NOT_EXIT=true
ANTLR_USE_DIRECT_CLASS_LOADING=true
awt.toolkit=sun.awt.windows.WToolkit
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\Program
Files\Java\eclipse-3.3.0\\plugins\org.eclipse.platform_3.3.2 .R33x_v20071022\splash.bmp
-launcher
C:\Program Files\Java\eclipse-3.3.0\eclipse.exe
-name
Eclipse
--launcher.library
C:\Program
Files\Java\eclipse-3.3.0\plugins\org.eclipse.equinox.launche r.win32.win32.x86_1.0.2.R331_v20071019\eclipse_1021.dll
-startup
C:\Program
Files\Java\eclipse-3.3.0\plugins\org.eclipse.equinox.launche r_1.0.1.R33x_v20070828.jar
-vm
C:\Program Files\Java\jre1.6.0_02\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1194595498125
eclipse.vm=C:\Program Files\Java\jre1.6.0_02\bin\client\jvm.dll
eclipse.vmargs=-XX:+UseParallelGC
-XX:MaxPermSize=256M
-Xmx512M
-Xss4M
-Djava.class.path=C:\Program
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre1.6.0_02\lib\endorsed
java.ext.dirs=C:\Program
Files\Java\jre1.6.0_02\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre1.6.0_02
java.io.tmpdir=C:\DOCUME~1\pm\LOCALS~1\Temp\
java.library.path=C:\Program
Files\Java\eclipse-3.3.0;.;C:\WINDOWS\Sun\Java\bin;C:\WINDOW S\system32;C:\WINDOWS;C:\Program
Files\Java\jre1.6.0_02\bin\client;C:\Program
Files\Java\jre1.6.0_02\bin;C:\Program Files\Windows Resource
Kits\Tools\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System 32\Wbem;C:\PROGRA~1\Java\JDK16~1.0_0\bin;C:\PROGRA~1\Java\MA VEN-~1.7\bin;C:\PROGRA~1\XSDVAL~1;C:\Program
Files\Common
Files\GTK\2.0\bin;C:\PROGRA~1\SUBVER~1\COLLAB~1;C:\PROGRA~1\ GNU\GnuPG;C:\PROGRA~1\ATT\Graphviz\bin;C:\PROGRA~1\Java\APAC HE~1.0\bin;C:\Program
Files\MySQL\MySQL Server 5.0\bin
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_02-b06
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.6.0_02-b06
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off
org.eclipse.equinox.launcher.splash.location=C:\Program
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.
kerberos,javax.security.auth.login,javax.security.auth.spi,j avax.security.auth.x500,javax.security.cert,javax.security.s asl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sample d,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.s ql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swin g.border,javax.swing.colorchooser,javax.swing.event,javax.sw ing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,java x.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.s ynth,javax.swing.table,javax.swing.text,javax.swing.text.htm l,javax.swing.text.html.parser,javax.swing.text.rtf,javax.sw ing.tree,javax.swing.undo,javax.tools,javax.transaction,java x.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.ann otation,javax.xml.bind.annotation.adapters,javax.xml.bind.at tachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xm l.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xm l.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.cr ypto.dsig.spec,javax.xml.datat
ype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,jav ax.xml.stream,javax.xml.stream.events,javax.xml.stream.util, javax.xml.transform,javax.xml.transform.dom,javax.xml.transf orm.sax,javax.xml.transform.stax,javax.xml.transform.stream, javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax .xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,jav ax.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,or g.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.Dyn AnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,o rg.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNa ming.NamingContextExtPackage,org.omg.CosNaming.NamingContext Package,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAn y.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org. omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPac kage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.P ortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer ,org.omg.PortableServer.Curren
tPackage,org.omg.PortableServer.POAManagerPackage,org.omg.Po rtableServer.POAPackage,org.omg.PortableServer.portable,org. omg.PortableServer.ServantLocatorPackage,org.omg.SendingCont ext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap, org.w3c.dom.events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ex t,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\Documents and
Settings\pm\.eclipse\org.eclipse.platform_3.3.0_1900124320\c onfiguration\org.eclipse.osgi\bundles
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/C:/Documents and
Settings/pm/.eclipse/org.eclipse.platform_3.3.0_1900124320/c onfiguration/
osgi.framework=file:/c:/Program
Files/Java/eclipse-3.3.0/plugins/org.eclipse.osgi_3.3.1.R33x _v20070828.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.3.1.R33x_v20070828
osgi.install.area=file:/C:/Program Files/Java/eclipse-3.3.0/
osgi.instance.area=file:/C:/documents/pm/eclipse-3.3-workspa ces/wirexn-projects/
osgi.instance.area.default=file:/C:/Documents and Settings/pm/workspace/
osgi.logfile=C:\documents\pm\eclipse-3.3-workspaces\wirexn-p rojects\.metadata\.log
osgi.manifest.cache=C:\Documents and
Settings\pm\.eclipse\org.eclipse.platform_3.3.0_1900124320\c onfiguration\org.eclipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.sharedConfiguration.area=file:/c:/Program
Files/Java/eclipse-3.3.0/configuration/
osgi.splashLocation=C:\Program
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\Program Files\Java\eclipse-3.3.0\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jre1.6.0_02\lib\resources.jar;C:\Program
Files\Java\jre1.6.0_02\lib\rt.jar;C:\Program
Files\Java\jre1.6.0_02\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.6.0_02\lib\jsse.jar;C:\Program
Files\Java\jre1.6.0_02\lib\jce.jar;C:\Program
Files\Java\jre1.6.0_02\lib\charsets.jar;C:\Program
Files\Java\jre1.6.0_02\classes
sun.boot.library.path=C:\Program Files\Java\jre1.6.0_02\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486
i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1255
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
tptp.automation.command=execute
user.country=US
user.dir=C:\PROGRA~1\Java\ECLIPS~2.0
user.home=C:\Documents and Settings\pm
user.language=en
user.name=pm
user.timezone=Asia/Jerusalem
user.variant=
*** Features:
com.atlassw.tools.eclipse.checkstyle (4.3.3) "Checkstyle Plug-in"
com.oxygenxml.editor (8.2.0) "oXygen XML Editor"
com.soyatec.euml2.free (3.0.2.20071029) "eUML2 Free Edition"
fr.obeo.acceleo (2.1.1.200708011733) "Acceleo Generator Ui Plug-in"
net.sourceforge.ehep (0.3.0) "Ehep Plug-in"
net.sourceforge.metrics (1.3.6) "metrics Plug-in"
org.apache.batik (1.6.0.v20061222-1222-0842283444-3444) "Apache Batik"
org.eclipse.core.tools (1.4.0.200607170928) "Core Tools"
org.eclipse.cvs (1.0.1.R33x_r20070802-7C79_9_KKG-mDM9e3H5D) "Eclipse CVS
Client"
org.eclipse.cvs.source (1.0.1.R33x_r20070802-7C79_9_KKG-mDM9e3H5D)
"Eclipse CVS Client SDK"
org.eclipse.datatools.connectivity.feature (1.5.1.200709261) "Data Tools
Platform Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature
(1.5.1.200709261) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.feature (1.5.1.200709261) "DTP
Open Data Access"
org.eclipse.datatools.doc.user (1.5.1.200709261) "Data Tools Platform
User Guide"
org.eclipse.datatools.enablement.feature (1.5.1.200709261) "Eclipse Data
Tools Platform Enablement"
org.eclipse.datatools.enablement.mysql.feature (1.5.1.200709261)
"Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.intro (1.5.1.200709261) "Eclipse Data Tools
Platform Intro Plug-in"
org.eclipse.datatools.modelbase.feature (1.5.1.200709261) "Eclipse Data
Tools Platform SQLModel Plug-in"
org.eclipse.datatools.sdk.feature (1.5.1.200709261) "Data Tools Platform
Source Code"
org.eclipse.datatools.sqldevtools.feature (1.5.1.200709261) "Eclipse
Data Tools Platform SQL Tools Common UI Plug-in"
org.eclipse.emf (2.3.1.v200709252135) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.codegen (2.3.1.v200709252135) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.3.1.v200709252135) "EMF Ecore Code
Generation"
org.eclipse.emf.codegen.ecore.ui (2.3.0.v200709252135) "EMF Ecore Code
Generation UI"
org.eclipse.emf.codegen.ui (2.3.0.v200709252135) "EMF Template Code
Generator UI"
org.eclipse.emf.common (2.3.0.v200709252135) "EMF Common"
org.eclipse.emf.common.ui (2.3.1.v200709252135) "EMF Common UI"
org.eclipse.emf.converter (2.3.1.v200709252135) "EMF Model Convert Support"
org.eclipse.emf.ecore (2.3.1.v200709252135) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.3.0.v200709252135) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.3.1.v200709252135) "Sample Ecore Editor"
org.eclipse.emf.ecore.sdo (2.3.0.v200709252135) "EMF Service Data
Objects (SDO)"
org.eclipse.emf.edit (2.3.1.v200709252135) "EMF Edit"
org.eclipse.emf.edit.ui (2.3.1.v200709252135) "EMF Edit UI"
org.eclipse.emf.mapping (2.3.0.v200709252135) "EMF Mapping "
org.eclipse.emf.mapping.ecore (2.3.0.v200709252135) "Eclipse Modeling
Framework (EMF) - org.eclipse.emf.mapping.ecore"
org.eclipse.emf.mapping.ecore.editor (2.3.0.v200709252135) "Eclipse
Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor"
org.eclipse.emf.mapping.ui (2.3.0.v200709252135) "EMF Mapping UI"
org.eclipse.emf.ocl (1.1.1.v200709121956-1007w31181_232_67) "Object
Constraint Language (OCL) 2.0 Compatibility API"
org.eclipse.emf.query (1.1.0.v200706071712-10-7w311817182823) "EMF Model
Query"
org.eclipse.emf.query.ocl (1.1.0.v200706071712-10-7w311817182823) "EMF
Model Query OCL Integration"
org.eclipse.emf.transaction (1.1.1.v200708231948-208Z8s733G3G5C5I9D)
"EMF Model Transaction Core"
org.eclipse.emf.validation (1.1.1.v200708161445-318Z9oA55P5O6O8IC_) "EMF
Validation Framework Core"
org.eclipse.emf.workspace (1.1.1.v200707252036-208Z8s733G3F5E6_8B) "EMF
Model Transaction Workbench Integration Core"
org.eclipse.gef (3.3.1.v20070814) "Graphical Editing Framework"
org.eclipse.gmf (1.0.100.v20070921-0000-7d-ETjEYjiMWQYLSEejlRjypkm71)
"Graphical Modeling Framework"
org.eclipse.jdt (3.3.1.r331_v20070629-7o7jE72EDlXAbqAcnbmyg1rf8RIL)
"Eclipse Java Development Tools"
org.eclipse.jdt.source
(3.3.1.r331_v20070629-7o7jE72EDlXAbqAcnbmyg1rf8RIL) "Eclipse Java
Development Tools SDK"
org.eclipse.jpt.feature.source (1.0.0.v200706250000-77--CYQCCz-CoRPCCCH)
"Dali Java Persistence API (JPA) Tools"
org.eclipse.jst (2.0.1.v200709110510-7B-68dDTNImaz0di_Tvks1JyDPVe) "J2EE
Standard Tools (JST)"
org.eclipse.jst.common_core.feature.source
(2.0.0.v200706041905-1007w311817231426) "J2EE Standard Tools - Common
Core Source"
org.eclipse.jst.enterprise_core.feature.source
(2.0.1.v200709130705-42Aq_kE77Y7gBHDE77) "J2EE Standard Tools -
Enterprise Core Source"
org.eclipse.jst.enterprise_ui.feature.source
(2.0.1.v200709130705-7b7_ErsEU6AXKM4z-H2OSyjeRYcY) "J2EE Standard Tools
- Enterprise UI Source"
org.eclipse.jst.sdk (2.0.1.v200709110510-7F-788fNWpoJCFladAFBfkeXa3lR)
"J2EE Standard Tools (JST)"
org.eclipse.jst.server_adapters.feature.source
(2.0.1.v200709110550-787KE8gDUUEF6F_KxpHEQ) "J2EE Standard Tools -
Server Adapters Source"
org.eclipse.jst.server_core.feature.source
(2.0.1.v200709110550-56CQ9rC7EK_UAblGAD2537) "J2EE Standard Tools -
Server Core Source"
org.eclipse.jst.server_ui.feature.source
(2.0.1.v200709110550-77-CR9yJXEkuiKVeQrclqTHQ3648) "J2EE Standard Tools
- Server UI Source"
org.eclipse.jst.web_core.feature.source
(2.0.200.v200709122200-7Q7AE7BEHhHegvh89ftNyC) "J2EE Standard Tools -
Web Core Source"
org.eclipse.jst.web_ui.feature.source
(2.0.1.v200709110605-7B1COCkuNa_RHevwkwAwi9_guOz-) "J2EE Standard Tools
- Web UI Source"
org.eclipse.jst.webpageeditor.feature.source
(1.0.1.v200709110605-3-29oA55P5V8A) "Web Page Editor Source"
org.eclipse.mylyn_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.mylyn.context_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.mylyn.ide_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.mylyn.java_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.mylyn.pde_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.mylyn.trac_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.ocl (1.1.1.v200707131415-3209oA55P5N7F8JDH) "Object
Constraint Language (OCL) 2.0 Parser/Interpreter"
org.eclipse.pde (3.3.2.R33x_r20071022-7N7M4CYWLBCz-yHkMIuHN) "Eclipse
Plug-in Development Environment"
org.eclipse.pde.source (3.3.2.R33x_r20071022-7N7M4CYWLBCz-yHkMIuHN)
"Eclipse Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.3.2.R33x_v20071022-_19UEksF-G8Yc6bUv3Dz)
"Eclipse Platform"
org.eclipse.platform.source (3.3.2.R33x_v20071022-_19UEksF-G8Yc6bUv3Dz)
"Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.3.2.R33x_r20071022-8y8eE9CEV3FspP8HJrY1M2dS) "Eclipse
RCP"
org.eclipse.rcp.source (3.3.2.R33x_r20071022-8y8eE9CEV3FspP8HJrY1M2dS)
"Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.3.2.R33x_r20071022-7M7J7C_Mu2gop0b_GAwplOBhyuKO)
"Eclipse Project SDK"
org.eclipse.tptp.monitoring (4.4.1.v200707080100-7c7KEFJ7IYGHEHWXBQ5xe)
"TPTP Monitoring"
org.eclipse.tptp.monitoring.doc.user
(4.3.101.v200709261752-774Ai0r733G3K7E5GC7) "TPTP Monitoring Project
Documentation"
org.eclipse.tptp.monitoring.examples
(4.3.101.v200709261752-328Z-w31181_372863) "User examples for the TPTP
Monitoring Tools Plugins"
org.eclipse.tptp.monitoring.instrumentation
(4.3.1.v200709261752-7A7921mA55P5VAM8PJA) "TPTP Instrumentation Monitoring "
org.eclipse.tptp.monitoring.la.core
(4.4.1.v200707080100-7A78_91mA55P5S7N7_CE) "Monitoring Log Analyzer Core"
org.eclipse.tptp.monitoring.managedagent
(4.4.1.v200709261752-7E7D8c2hE77Y7gEUAYQE) "Managed Agent Plugin"
org.eclipse.tptp.monitoring.managedagent.agents
(4.4.1.v200709261752-330-w31181_372863) "JMX Managed Agent"
org.eclipse.tptp.monitoring.mx4j.jmx
(4.4.1.v200709261752-2-2-w31181_372863) "MX4J"
org.eclipse.tptp.monitoring.profile.server
(4.2.101.v200709261752-318Z-w31181_372863) "TPTP Profile On Server
Logging Utility"
org.eclipse.tptp.platform.analysis
(4.4.1.v200709191245-7E7_CI2hE77Y7gCaAOOK) "TPTP Analysis"
org.eclipse.tptp.platform.analysis.codereview.java
(4.4.100.v200709191245-777710r733G3K5K57AC) "Java Code Review Plug-in"
org.eclipse.tptp.platform.analysis.engine
(4.3.101.v200709261752-773CG0r733G3K7E5GC7) "TPTP Analysis Engine"
org.eclipse.tptp.platform.core
(4.4.1.v200707090100-8Q82ENLJEPilAlvO15vQb) "TPTP Platform"
org.eclipse.tptp.platform.core.doc.user
(4.3.101.v200709261752-7A6CH1mA55P5VAM8PJA) "TPTP Platform Project
Documentation"
org.eclipse.tptp.platform.doc.user
(4.3.101.v200709261752-7A77CH08IIrT11IGIcOfKRIYPB) "TPTP Platform
Project Documentation"
org.eclipse.tptp.platform.examples
(4.3.101.v200709261752-328Z-w31181_372863) "TPTP Platform Examples"
org.eclipse.tptp.platform.instrumentation.ui
(4.2.1.v200709261752-320-w31181_372863) "Instrument Core UI"
org.eclipse.tptp.platform.integration.pde
(4.4.1.v200709261752-330-w31181_372863) "TPTP Platform Integration PDE"
org.eclipse.tptp.platform.jvmti
(4.3.1.v200709261752-777710r733G3K7E5GC7) "TPTP JVMTI Profiler Client"
org.eclipse.tptp.platform.la.core
(4.3.101.v200707090100-328Z-w31181_2_2356) "Log Analysis Core"
org.eclipse.tptp.platform.lta
(4.3.101.v200707090100-773Ai0r733G3K6H5BB_) "TPTP Log and Trace Analyzer"
org.eclipse.tptp.platform.probekit
(4.3.101.v200709261752-7E5EAY2hE77Y7gEUAYQE) "TPTP ProbeKit"
org.eclipse.tptp.platform.probekit.doc.user
(4.3.101.v200709261752-318Z-w31181_372863) "Probekit User Documentation"
org.eclipse.tptp.platform.profile.server
(4.3.1.v200709261752-7E798c2hE77Y7gEUAYQE) "TPTP Profile on Server"
org.eclipse.tptp.platform.report
(4.2.101.v200709261752-7A5CH1mA55P5VAM8PJA) "TPTP Charting Service"
org.eclipse.tptp.platform.samples
(4.3.101.v200709261752-7A4Dr1mA55P5VAM8PJA) "TPTP Platform Samples"
org.eclipse.tptp.platform.statistical.ui
(4.1.301.v200709261752-772CG0r733G3K7E5GC7) "TPTP Statistical UI"
org.eclipse.tptp.platform.trace
(4.3.101.v200707090100-7E7AAk2hE77Y7gDXATPH) "TPTP Platform Trace"
org.eclipse.tptp.test (4.3.101.v200709261752-7I7ACJ3cI99h9rIcDhXI) "TPTP
Test"
org.eclipse.tptp.test.auto (4.1.100.v200705040100-773_70r733G3B8A3C76)
"TPTP Automated GUI Recording and Playback"
org.eclipse.tptp.test.doc.user (4.3.101.v200709261752-320-w31181_372863)
"Test Tools User Documentation"
org.eclipse.tptp.test.samples (4.2.1.v200709261752-310-w31181_372863)
"TPTP Test Samples"
org.eclipse.tptp.test.tools
(4.3.101.v200709261752-7E7C31vNDHT9HNTErQiBN9QKB) "TPTP Test Tools"
org.eclipse.tptp.test.tools.api (4.3.0.v200705040100-32--w311816151211)
"TPTP API Recorder Framework and Test Tools"
org.eclipse.tptp.test.tools.junit
(4.4.1.v200709261752-7A7A21mA55P5VAM8PJA) "TPTP JUnit Plugin Test Tools"
org.eclipse.tptp.trace (4.2.1.v200709261752-771E9y0r733G3K7E5GC7) "TPTP
Trace"
org.eclipse.tptp.trace.arm (4.2.1.v200709261752-77210r733G3K7E5GC7)
"TPTP ARM Monitoring "
org.eclipse.tptp.trace.arm.ui (4.3.1.v200709261752-77510r733G3K7E5GC7)
"Instrument ARM UI"
org.eclipse.tptp.trace.jvmti (4.2.1.v200709261752-330-w31181_372863)
"TPTP Trace JVMTI Client"
org.eclipse.uml2 (2.1.1.v200708301222) "UML2"
org.eclipse.uml2.diagram (0.7.1.v200710010534) "UML2 Diagramming Plug-in
(Incubation)"
org.eclipse.uml2.doc (2.1.1.v200707181556) "UML2 Documentation"
org.eclipse.uml2.examples (2.1.0.v200706251652) "UML2 Examples"
org.eclipse.uml2.examples.source (2.1.0.v200706251652) "UML2 Examples
Source"
org.eclipse.uml2.source (2.1.1.v200708301222) "UML2 Source"
org.eclipse.uml2tools (0.7.1.v200710010534) "UML2 Tools Plug-in
(Incubation)"
org.eclipse.uml2tools.doc (0.7.0.v200710010534) "UML2 Tools
Documentation Plug-in"
org.eclipse.wst (2.0.1.v200709110510-7C-778k0JWNr93WEIHvplSVojWel) "Web
Standard Tools (WST)"
org.eclipse.wst.common_core.feature.source
(2.0.1.v200709110622-7C78EKGE_EkMNfNleyerlz) "Web Standard Tools -
Common Core Source"
org.eclipse.wst.common_ui.feature.source
(2.0.1.v200709110622-7C5EH2E9RvTVnijrspVz0bgOmfz-) "Web Standard Tools -
Common UI Source"
org.eclipse.wst.sdk (2.0.1.v200709110510-7E-788aNUivSRfjWLEcbxlUXG72x)
"Web Standard Tools (WST)"
org.eclipse.wst.server_core.feature.source
(2.0.1.v200709110637-2-CM8s733G3G5Jc) "Web Standard Tools - Server Core
Source"
org.eclipse.wst.server_ui.feature.source
(2.0.1.v200709110637-77-CU9vCXCjvdHL7ATINi447) "Web Standard Tools -
Server UI Source"
org.eclipse.wst.web_core.feature.source
(2.0.1.v200709111200-42CK_kE77Y7ZBNCQGG) "Web Standard Tools - Web Core
Source"
org.eclipse.wst.web_ui.feature.source
(2.0.1.v200709111200-7A0EAiCiWfGJsJZlAhE3TMaQW) "Web Standard Tools -
Web UI Source"
org.eclipse.wst.ws_core.feature.source
(2.0.1.v200709051445-7E7KEB0EC3wSU4Tuh9iKz) "Web Standard Tools - Web
Service Core Source"
org.eclipse.wst.ws_ui.feature.source
(2.0.1.v200709051445-791ECFAufYO8Az-ajoKBCFe8tVjL) "Web Standard Tools -
Web Service UI Source"
org.eclipse.wst.xml_core.feature.source
(2.0.1.v200709110650-787BE_1CYQCCz-CvRQLQSV) "Web Standard Tools - XML
Core Source"
org.eclipse.wst.xml_ui.feature.source
(2.0.1.v200709110650-7A1ECGCnbckz0bnr5wCp8KNAjipR) "Web Standard Tools -
XML UI Source"
org.eclipse.xsd (2.3.1.v200709252135) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.edit (2.3.0.v200709252135) "XML Schema Edit Framework"
org.polarion.team.svn.mylyn (1.0.9) "Subversive Integration for the
Mylyn Project"
org.polarion.team.svn.resource.ignore.rules.jdt (1.0.4) "Subversive JDT
Ignore Recommendations"
org.topcased.modeler.ecore (1.0.0.v200709210925) "Ecore Editor"
org.topcased.modeler.uml (1.0.0.v200709210925) "UML Editor"
Re: IWAT4039E The Test Execution Harness reported the following problems:Failed to retrieve the cont [message #117716 is a reply to message #117665] Fri, 09 November 2007 06:23 Go to previous messageGo to next message
Paul Slauenwhite is currently offline Paul Slauenwhite
Hi Adrian,
What type of test are you running? Are you using the IAC or Agent
Controller?
Paul
"Adrian Herscu" <bmf1972@fastmail.fm> wrote in message
news:fh14ug$3pf$1@build.eclipse.org...
>exception:
> test cases in
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> win32
> -ws
> win32
> -arch
> x86
> -showsplash
> C:\Program
> -launcher
> -name
> Eclipse
> --launcher.library
> C:\Program
> -startup
> C:\Program
> -vm
> -Xmx512M
> -Xss4M
> eof=eof
> file.separator=\
> Files\Common
> line.separator=
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.nl=en_US
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386
> i86
> sun.desktop=windows
> user.country=US
> user.language=en
> user.name=pm
> user.variant=
> *** Features:
> Client"
> org.eclipse.datatools.connectivity.oda.designer.feature (1.5.1.200709261)
> org.eclipse.datatools.connectivity.oda.feature (1.5.1.200709261) "DTP Open
> Data Access"
> org.eclipse.datatools.doc.user (1.5.1.200709261) "Data Tools Platform User
> Guide"
> org.eclipse.datatools.enablement.mysql.feature (1.5.1.200709261) "Eclipse
> org.eclipse.datatools.intro (1.5.1.200709261) "Eclipse Data Tools Platform
> Intro Plug-in"
> Source Code"
> org.eclipse.datatools.sqldevtools.feature (1.5.1.200709261) "Eclipse Data
> Generator"
> Generation"
> Generation UI"
> Generator UI"
> Support"
> org.eclipse.emf.ecore.sdo (2.3.0.v200709252135) "EMF Service Data Objects
> (SDO)"
> Query"
> org.eclipse.emf.transaction (1.1.1.v200708231948-208Z8s733G3G5C5I9D) "EMF
> org.eclipse.jdt.source (3.3.1.r331_v20070629-7o7jE72EDlXAbqAcnbmyg1rf8RIL)
> "Eclipse Java Development Tools SDK"
> (2.0.0.v200706041905-1007w311817231426) "J2EE Standard Tools - Common Core
> Source"
> (2.0.1.v200709130705-42Aq_kE77Y7gBHDE77) "J2EE Standard Tools - Enterprise
> Core Source"
> (2.0.1.v200709130705-7b7_ErsEU6AXKM4z-H2OSyjeRYcY) "J2EE Standard Tools -
> (2.0.1.v200709110550-787KE8gDUUEF6F_KxpHEQ) "J2EE Standard Tools - Server
> Adapters Source"
> (2.0.1.v200709110550-56CQ9rC7EK_UAblGAD2537) "J2EE Standard Tools - Server
> Core Source"
> (2.0.1.v200709110550-77-CR9yJXEkuiKVeQrclqTHQ3648) "J2EE Standard Tools -
> Server UI Source"
> (2.0.200.v200709122200-7Q7AE7BEHhHegvh89ftNyC) "J2EE Standard Tools - Web
> Core Source"
> (2.0.1.v200709110605-7B1COCkuNa_RHevwkwAwi9_guOz-) "J2EE Standard Tools -
> Web UI Source"
> org.eclipse.ocl (1.1.1.v200707131415-3209oA55P5N7F8JDH) "Object Constraint
> org.eclipse.platform (3.3.2.R33x_v20071022-_19UEksF-G8Yc6bUv3Dz) "Eclipse
> Platform"
> RCP"
> "TPTP Monitoring"
> Documentation"
> (4.2.101.v200709261752-318Z-w31181_372863) "TPTP Profile On Server Logging
> Utility"
> org.eclipse.tptp.platform.core (4.4.1.v200707090100-8Q82ENLJEPilAlvO15vQb)
> "TPTP Platform"
> Documentation"
> (4.3.101.v200709261752-7A77CH08IIrT11IGIcOfKRIYPB) "TPTP Platform Project
> Documentation"
> org.eclipse.tptp.platform.jvmti (4.3.1.v200709261752-777710r733G3K7E5GC7)
> org.eclipse.tptp.platform.lta (4.3.101.v200707090100-773Ai0r733G3K6H5BB_)
> Test"
> "TPTP Test Samples"
> Trace"
> org.eclipse.tptp.trace.arm (4.2.1.v200709261752-77210r733G3K7E5GC7) "TPTP
> ARM Monitoring "
> "Instrument ARM UI"
> org.eclipse.tptp.trace.jvmti (4.2.1.v200709261752-330-w31181_372863) "TPTP
> Trace JVMTI Client"
> (Incubation)"
> Source"
> (Incubation)"
> org.eclipse.uml2tools.doc (0.7.0.v200710010534) "UML2 Tools Documentation
> Plug-in"
> (2.0.1.v200709110622-7C78EKGE_EkMNfNleyerlz) "Web Standard Tools - Common
> Core Source"
> Common UI Source"
> Source"
> Server UI Source"
> Source"
> (2.0.1.v200709111200-7A0EAiCiWfGJsJZlAhE3TMaQW) "Web Standard Tools - Web
> UI Source"
> Core Source"
> XML UI Source"
> org.polarion.team.svn.mylyn (1.0.9) "Subversive Integration for the Mylyn
> Project"
Re: IWAT4039E The Test Execution Harness reported the following problems:Failed to retrieve the cont [message #118074 is a reply to message #117716] Tue, 13 November 2007 04:12 Go to previous messageGo to next message
Eclipse User
Paul, I am sorry about the late reply (the Eclipse news server was dawn
yesterday...).
I was trying to run an AGR test. As I said, it used to run before the
latest Eclipse updates; I never succeeded to make it run in headless
mode through Ant, but that's another story...
I never succeeded to make it run through the IAC, so I configured the
Agent Controller to run as a Windows service.
Adrian.
Paul Slauenwhite wrote:
> Hi Adrian,
> Controller?
> Paul
>> exception:
>> test cases in
>> win32
>> -ws
>> win32
>> -arch
>> x86
>> -showsplash
>> C:\Program
>> -launcher
>> -name
>> Eclipse
>> --launcher.library
>> C:\Program
>> -startup
>> C:\Program
>> -vm
>> -Xmx512M
>> -Xss4M
>> eof=eof
>> file.separator=\
>> Files\Common
>> line.separator=
th.
atat
>> ype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,jav ax.xml.stream,javax.xml.stream.events,javax.xml.stream.util, javax.xml.transform,javax.xml.transform.dom,javax.xml.transf orm.sax,javax.xml..transform.stax,javax.xml.transform.stream ,javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,java x.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,ja vax.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,o rg.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.Dy nAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable, org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosN aming.NamingContextExtPackage,org.omg.CosNaming.NamingContex tPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicA ny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org .omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPa ckage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg. PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServe r,org.omg.PortableServer.Cu
rren
>> os.arch=x86
>> os.name=Windows XP
>> os.version=5.1
>> osgi.arch=x86
>> osgi.nl=en_US
>> osgi.os=win32
>> osgi.ws=win32
>> path.separator=;
>> i86
>> sun.desktop=windows
>> user.country=US
>> user.language=en
>> user.name=pm
>> user.variant=
>> *** Features:
>> Client"
>> Data Access"
>> Guide"
>> Intro Plug-in"
>> Source Code"
>> Generator"
>> Generation"
>> Generation UI"
>> Generator UI"
>> Support"
>> (SDO)"
>> Query"
>> Source"
>> Core Source"
>> Adapters Source"
>> Core Source"
>> Server UI Source"
>> Core Source"
>> Web UI Source"
>> Platform"
>> RCP"
>> "TPTP Monitoring"
>> Documentation"
>> Utility"
>> "TPTP Platform"
>> Documentation"
>> Documentation"
>> Test"
>> "TPTP Test Samples"
>> Trace"
>> ARM Monitoring "
>> "Instrument ARM UI"
>> Trace JVMTI Client"
>> (Incubation)"
>> Source"
>> (Incubation)"
>> Plug-in"
>> Core Source"
>> Common UI Source"
>> Source"
>> Server UI Source"
>> Source"
>> UI Source"
>> Core Source"
>> XML UI Source"
>> Project"
Re: IWAT4039E The Test Execution Harness reported the following problems:Failed to retrieve the cont [message #118098 is a reply to message #118074] Tue, 13 November 2007 07:31 Go to previous message
Thanks Adrian. What version of TPTP are you running now? Can you attach
your test suite? Finally, can you attach the <Agent Controller
installation directory>/config/servicelog.log file?
Paul
news:fhbppv$q79$1@build.eclipse.org...
> yesterday...).
> latest Eclipse updates; I never succeeded to make it run in headless mode
> Adrian.
>> Hi Adrian,
>> Controller?
>> Paul
>>> exception:
>>> test cases in
>>> win32
>>> -ws
>>> win32
>>> -arch
>>> x86
>>> -showsplash
>>> C:\Program
>>> -launcher
>>> -name
>>> Eclipse
>>> --launcher.library
>>> C:\Program
>>> -startup
>>> C:\Program
>>> -vm
>>> -Xmx512M
>>> -Xss4M
>>> eof=eof
>>> file.separator=\
>>> Files\Common
>>> line.separator=
> th.
> atat
> rren
>>> os.arch=x86
>>> os.name=Windows XP
>>> os.version=5.1
>>> osgi.arch=x86
>>> osgi.nl=en_US
>>> osgi.os=win32
>>> osgi.ws=win32
>>> path.separator=;
>>> i386 i86
>>> sun.desktop=windows
>>> user.country=US
>>> user.language=en
>>> user.name=pm
>>> user.variant=
>>> *** Features:
>>> Client"
>>> Open Data Access"
>>> User Guide"
>>> Source Code"
>>> Generator"
>>> Generation"
>>> Generation UI"
>>> Generator UI"
>>> Support"
>>> Support"
>>> Objects (SDO)"
>>> Query"
>>> Core Source"
>>> Tools - Enterprise UI Source"
>>> Server Core Source"
>>> Tools - Server UI Source"
>>> Web Core Source"
>>> Tools - Web UI Source"
>>> "Eclipse Platform"
>>> RCP"
>>> "TPTP Monitoring"
>>> Documentation"
>>> Monitoring "
>>> Core"
>>> Logging Utility"
>>> Documentation"
>>> Analyzer"
>>> Test"
>>> "TPTP Test Samples"
>>> Trace"
>>> "Instrument ARM UI"
>>> (Incubation)"
>>> Source"
>>> (Incubation)"
>>> Common Core Source"
>>> Common UI Source"
>>> Source"
>>> Server UI Source"
>>> Source"
>>> Web UI Source"
>>> Core Source"
>>> XML UI Source"
>>> Mylyn Project"
Previous Topic:Problems when profiling a standalone tomcat
Next Topic:CompilatioUnit.getCommentList(); - Where are the comments???
Current Time: Sat May 25 14:49:49 EDT 2013
Powered by FUDForum. Page generated in 0.02198 seconds
