Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » How can I start?
How can I start? [message #10610] Thu, 17 March 2005 08:01 Go to next message
Eclipse User
Originally posted by: agustinus.ivalidator.org
Hello everybody,
I am a newbie at Hyades framework. I have downloaded Hyades 3.2.0 and
run it well on Linux SuSE 8 platform. As a starting point I have
downloaded all Hyades plug-ins and there are around 70 plugins extracted.
1. When I run the "URL Test Sample", which plug-ins are actually in
action ? For instance when I double-click the eclipseTest.testsuite,
there will be an editor opened on the workbench, with 3 tabfolders,
Overview, Http Requests and Behavior. Do these three tabfolders
correspond to certain plug-ins ?
2. I see also that some plug-ins have no extension and no
extension-points. The plug-in contains only *.jar file and is used only
for dependency for other plug-ins. Am I correct?
3. Where is the main plug-ins so that a newbie can start easily?
Thank you very much for any opinions.
Agustinus Tedja
Re: How can I start? [message #11682 is a reply to message #10610] Thu, 24 March 2005 10:57 Go to previous messageGo to next message
Todd Merriweather is currently offline Todd Merriweather
Agustinus Tedja wrote:
> Hello everybody,
> Best regards,
> Agustinus Tedja
Agustinus,
1. The URL Test Sample is a collection of assets that can be inspected
so that new users can "sample" URL Test without actually running one.
The creation of the sample project is handled by Eclipse functionality.
You can reference org.eclipse.hyades.ui.sample/plugin.xml to see the
details.
A good place to start to see what plugins are involved when you open a
testsuite is to look at org.eclipse.hyades.test.http/plugin.xml.
2. I'm not sure about this
3. The main plugins that comprise URL Test are:
-org.eclipse.hyades.test.http
-org.eclipse.hyades.execution.recorder
-org.eclipse.hyades.execution.recorder.http
-org.eclipse.hyades.execution.testgen
-org.eclipse.hyades.execution.testgen.http
Re: How can I start? [message #11719 is a reply to message #11682] Fri, 25 March 2005 11:01 Go to previous message
Scott E. Schneider is currently offline Scott E. Schneider
Hello Agustinus,
For point #2, yes, this is true, for example
org.eclipse.hyades.test.common follows that role as you described (no
extensions or extension-points specified).
-Scott E. Schneider
IBM Rational, Raleigh, NC
>> Hello everybody,
>> only for dependency for other plug-ins. Am I correct?
>> Best regards,
>> Agustinus Tedja
> Agustinus,
> details.
Previous Topic:Multiple instances of Agent connected to a client
Next Topic:piAgent don't scale
Current Time: Tue May 21 13:02:58 EDT 2013
Powered by FUDForum. Page generated in 0.01700 seconds
