Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » TPTP 4.4.0.3 is released!
TPTP 4.4.0.3 is released! [message #113564] Mon, 01 October 2007 06:47 Go to next message
Paul Slauenwhite is currently offline Paul Slauenwhite
TPTP Community,
The TPTP 4.4.0.3 maintenance release is now available for download:
http://www.eclipse.org/tptp/home/downloads/?ver=4.4.0.3
This maintenance release improves on the recent TPTP 4.4.0 release,
which is part of Europa. For more information on the TPTP 4.4.0 release,
see:
New and Noteworthy:
http://www.eclipse.org/tptp/home/downloads/whatsnew/v440/new _and_noteworthy.html
Quick Tour:
http://www.eclipse.org/tptp/home/downloads/quicktour/v44/qui ck_tour.html
For TPTP 4.4.0 users, update to the TPTP 4.4.0.3 release from the TPTP
Update Site (Test and Performance Tools Platform (TPTP) Updates) using the
Update Manager. For more information, see:
http://www.eclipse.org/tptp/home/downloads/updateManager.php
Re: TPTP 4.4.0.3 is released! [message #114148 is a reply to message #113564] Thu, 04 October 2007 15:54 Go to previous messageGo to next message
Eclipse User
Originally posted by: me.myhouse.com
still has the same bug as the previous all in one release, which is this
(while trying to profile a medium-sized swing application on windows XP,
nothing too fancy):
org.eclipse.core.runtime.CoreException
A time-out occurred while attempting to launch the process
org.eclipse.core.runtime.CoreException: A time-out occurred while
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:123)
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:131)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.handleError(TIDelegateHelper.java:596)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launchProcess(TIDelegateHelper.java:512)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launch(TIDelegateHelper.java:312)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TIJ avaLauncherDelegate.launch(TIJavaLauncherDelegate.java:37)
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.delegateInit(LauncherUtility.java:1153)
org.eclipse.tptp.trace.ui.provisional.launcher.PrimaryLaunch Delegate.run(PrimaryLaunchDelegate.java:196)
at java.lang.Thread.run(Thread.java:595)
Paul Slauenwhite wrote:
> TPTP Community,
> see:
Re: TPTP 4.4.0.3 is released! [message #114176 is a reply to message #114148] Fri, 05 October 2007 02:31 Go to previous messageGo to next message
Igor Alelekov is currently offline Igor Alelekov
Could you try a TPTP 4.4.1 build as well?
Igor
Re: TPTP 4.4.0.3 is released! [message #114206 is a reply to message #114148] Fri, 05 October 2007 04:17 Go to previous messageGo to next message
Eclipse User
Originally posted by: mauro.molinari.cardinis.com
Handlingspezi ha scritto:
> nothing too fancy):
your problem may be the same I was encountering too:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201474
It is fixed for 4.4.1, but not for 4.4.0.x.
Mauro.
Re: TPTP 4.4.0.3 is released! [message #114356 is a reply to message #114176] Fri, 05 October 2007 11:39 Go to previous messageGo to next message
Eclipse User
Igor Alelekov wrote:
> Igor
Hi Igor,
thanks for the tip: tried it (deleted 4.4.0.x, installed
TPTP-4.4.1-200709101254 all-in-one)
got this:
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.handleError(TIDelegateHelper.java:597)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launchProcess(TIDelegateHelper.java:513)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launch(TIDelegateHelper.java:313)
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.delegateInit(LauncherUtility.java:1163)
once again a simple HelloWorld is OK. But any sort of half-serious app
fails, stack dump looks exactly like the one I got in 4.4.0.x
If I select any of the "Agent Discoverer" or "Instrument Collector" then
my app starts, but (of couse) I don't get anything collected by TPTP. If
I select any of the options under "Java Profiling" JRE 1.5 options (my
JRE=(build 1.5.0_06-b05), then I get the above exception.
,Philip
Re: TPTP 4.4.0.3 is released! [message #114368 is a reply to message #114176] Fri, 05 October 2007 13:30 Go to previous message
Eclipse User
> Igor
Hi again,
just for fun I also tried the latest development build
tptp.runtime.allInOne.win32.win32.x86-TPTP-4.4.1-20071003010 0.zip.
It does exactly the same.
,Philip
Previous Topic:[agr] please explain the meaning of this exception
Next Topic:Non Integrated AC Agent crash
Current Time: Tue Jun 18 02:59:25 EDT 2013
Powered by FUDForum. Page generated in 0.01908 seconds
