| Deletion of Task [message #10822] |
Thu, 16 April 2009 09:11  |
Verena Messages: 17 Registered: July 2009 |
Junior Member |
Hi there,
I'm trying to delete the task that is automatically inserted on creation
of a pattern.
Currently I'm able to change the activitytype, id, name and so on, but I
did not found out how to delete it from the pool. Returning the vertices
of the pool and clearing the list does not make any difference...I also
tried calling removeAdapter, with the same result. Can someone give me a
hint how to delete it.
BTW: It would be better not to have the task anyway - is there a reason
why it is inserted there - if not is there a bug existing?
--Verena
| Re: Deletion of Task [message #11262 is a reply to message #10822] |
Thu, 16 April 2009 09:36   |
Originally posted by: atoulme.intalio.com
Verena wrote:
> Hi there,
> of a pattern.
You mean on creation of a new diagram, a pool and a task are present.
You just need to change the initial contents of the diagram, look at the
wizard code.
No. This was actually requested by users.
> --Verena
| Re: Deletion of Task [message #11372 is a reply to message #11262] |
Wed, 22 April 2009 03:43  |
Junior Member |
Antoine Toulme wrote:
> Verena wrote:
>> Hi there,
>> of a pattern.
This is exactly what I meant - sorry.
> wizard code.
I found out how to do that thanks. An other Problem occured to me. I'd
probably better open a new thread for that since thi shas nothing to do
with the topic. Thanks for your help.
FUDForum. Page generated in 0.06597 seconds
