| Could not parse big heap file [message #11369] |
Fri, 17 July 2009 13:36  |
Michael Wang Messages: 1 Registered: July 2009 |
Junior Member |
I have big heap dump file, nearly 3G. And I would like to use MAT to find
memory issue.
In XP window:
I downloaded MemoryAnalyzer-Incubation-0.8.0.20090617-win32.win32.x86.zip
and try to parse the heap file.
But eclipse gives me out of memory issue due to big heap file.
I can only increase Xmx to 1400m in MemoryAnalyzer.ini. If over 1400m, I
got
popup window indicating JVM terminated. Exit code=-1
I bet window eclipse can only support less than 1400m memory.
Then I try Unix version:
It gave following error when I try to use ParseHeapDump.sh <heapdumpfile>
!ENTRY org.eclipse.osgi 4 0 2009-07-17 12:17:06.169
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.mat.api.parse" could
not be found in the registry. The applications available are:
org.eclipse.ant.core.antRunner, org.eclipse.equinox.app.error,
org.eclipse.equinox.p2.artifact.repository.mirrorApplication ,
org.eclipse.equinox.p2.metadata.repository.mirrorApplication ,
org.eclipse.help.base.infocenterApplication,
org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool,
org.eclipse.ui.ide.workbench, org.eclipse.update.core.standaloneUpdate,
org.eclipse.update.core.siteOptimizer.
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
| Re: Could not parse big heap file [message #11407 is a reply to message #11369] |
Sun, 19 July 2009 11:45  |
Andreas Buchen Messages: 111 Registered: July 2009 |
Hi Michael,
this number of objects (i.e. the size of the object graph) determines how
much memory MAT needs. On 32bit machines this can be a problem. The good
news, once you parsed the file on a bigger box, you can still analyze it
on the smaller 32bit box.
This error tells that the parsing application has not been found. The
application is inside the "org.eclipse.mat.api" bundle. Look for the
logging messages before this one. It should give you a reason why the
bundle has not been activated / resolved. Common problems are: installed
via unzip into Eclipse (run with -clean option), MAT requires Java5 but it
is run with a Java4, the native parts have not the right bitsize (e.g.
running 32bit MAT version on a 64bit Java).
To run MAT on 64bit using a 32bit download, follow these instructions (you
have to updated the version numbers!):
http://wiki.eclipse.org/index.php/MemoryAnalyzer/FAQ#How_to_ run_on_64bit_VM_while_the_native_SWT_are_32bit
FUDForum. Page generated in 0.02545 seconds
