Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » [AGR] Obscure NullPointerException when playing back a test
| [AGR] Obscure NullPointerException when playing back a test [message #106054] |
Fri, 20 July 2007 15:13  |
Barbara Rosi-Schwartz Messages: 448 Registered: July 2009 |
Hi.
I have a test script that makes use of an object mine. When attempting
to play the script back in standard mode, the test script fails and the
..execution file shows the following NullPointerException:
There was an error while running the macro associated with the test
case: TC001. java.lang.NullPointerException
org.eclipse.tptp.test.auto.gui.internal.macro.MacroObjectLoc ator.lookupReferenceId(MacroObjectLocator.java:839)
org.eclipse.tptp.test.auto.gui.internal.commands.MacroComman dShell.load(MacroCommandShell.java:222)
org.eclipse.tptp.test.auto.gui.internal.macro.Macro.addShell (Macro.java:75)
org.eclipse.tptp.test.auto.gui.internal.macro.MacroManager.p lay(MacroManager.java:474)
org.eclipse.tptp.test.auto.gui.internal.runner.AutoGUIRunner $1$MacroPlayWrapper.run(AutoGUIRunner.java:619)
at java.lang.Thread.run(Unknown Source)
Everything appears all right at visual inspection. I have tried removing
both test script and object mine and re-recording, but I get the same
error message. From watching the script when it plays back, I can figure
out more or less where it is failing, but I cannot see anything wrong
with either the script or the mine. Nothing is shown in the Eclipse logs.
Any hints on how I could go about debugging this one? I am using
TPTP/AGR 4.4 with Eclipse Europa.
TIA,
B.
| Re: [AGR] Obscure NullPointerException when playing back a test [message #106122 is a reply to message #106093] |
Mon, 23 July 2007 09:31   |
Hi Paul.
Thanks for your reply. In actual fact some time during the weekend,
after re-recording the same test script a couple of times, it started
playing back properly again and unfortunately I do not have the merest
clue as to what might have been the problem when it was going wrong.
I was hoping for a hint on what to do in the future, other than doggedly
keeping on re-recording the same test, should this happen again, but I
guess you have no recommendation to give me. Please do correct me if
this is not the case.
Thank you very much and regards,
B.
Paul Slauenwhite wrote:
> Hi Barbara,
> After looking at the code, it appears that the object mine is not being
> loaded from the test suite. Can you attach the test suite in question so we
> can debug further?
> Paul
> "Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
> news:f7r1ha$tho$1@build.eclipse.org...
>> Hi.
>> I have a test script that makes use of an object mine. When attempting to
>> There was an error while running the macro associated with the test case:
>> at
>> at
>> at
>> at
>> at
>> out more or less where it is failing, but I cannot see anything wrong with
>> Any hints on how I could go about debugging this one? I am using TPTP/AGR
>> TIA,
>> B.
| Re: [AGR] Obscure NullPointerException when playing back a test [message #106243 is a reply to message #106122] |
Tue, 24 July 2007 05:55   |
Paul Slauenwhite Messages: 970 Registered: July 2009 |
Hi Barbara,
Unfortunately, we have to triage these issue on a case-by-case basis,
since this is not a known or expected behavior. If you come across the
problem in the future, open a defect and attach the test suite.
Paul
news:f82aj3$9ho$1@build.eclipse.org...
> Hi Paul.
> Thanks for your reply. In actual fact some time during the weekend, after
> re-recording the same test script a couple of times, it started playing
> back properly again and unfortunately I do not have the merest clue as to
> guess you have no recommendation to give me. Please do correct me if this
> is not the case.
> B.
>> Hi Barbara,
>> being loaded from the test suite. Can you attach the test suite in
>> question so we can debug further?
>> Paul
>> message news:f7r1ha$tho$1@build.eclipse.org...
>>> Hi.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> logs.
>>> TIA,
>>> B.
| Re: [AGR] Obscure NullPointerException when playing back a test [message #113227 is a reply to message #106243] |
Tue, 25 September 2007 04:23   |
Matthias Wiskow Messages: 25 Registered: July 2009 |
Junior Member |
perhaps this does not fit to the originally reported situation, but I
encountered the same problem after renaming the testsuite file.
Reverting to the original name helped.
This seems to be a bug. Didn't find any in BugZilla.
Matthias
> Hi Barbara,
> Paul
>> Hi Paul.
>> is not the case.
>> B.
>>> Hi Barbara,
>>> Paul
>>>> Hi.
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> logs.
>>>> TIA,
>>>> B.
| Re: [AGR] Obscure NullPointerException when playing back a test [message #113581 is a reply to message #113227] |
Mon, 01 October 2007 06:48  |
Hi Matthias,
Yes, there is an issue with renaming (as well as copying and moving)
test assets. This will be address under enhancement:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=166025
Paul
"Matthias Wiskow" <matthias.wiskow@windriver.com> wrote in message
news:fdagjj$t4e$1@build.eclipse.org...
> Matthias
>> Hi Barbara,
>> Paul
>> message news:f82aj3$9ho$1@build.eclipse.org...
>>> Hi Paul.
>>> B.
>>>> Hi Barbara,
>>>> Paul
>>>>> Hi.
>>>>> the .execution file shows the following NullPointerException:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> removing both test script and object mine and re-recording, but I get
>>>>> the same error message. From watching the script when it plays back, I
>>>>> can figure out more or less where it is failing, but I cannot see
>>>>> anything wrong with either the script or the mine. Nothing is shown in
>>>>> the Eclipse logs.
>>>>> TIA,
>>>>> B.
Current Time: Wed May 22 04:48:09 EDT 2013
Powered by FUDForum. Page generated in 0.06734 seconds
