Home » Archived » Memory Analyzer (MAT) » Setting up MAT with eclipse
Setting up MAT with eclipse [message #11227] Wed, 15 July 2009 08:35 Go to next message
Satish Burnwal is currently offline Satish Burnwal
I have installed MAT plugin with my eclipse ganymede using the update site
http://download.eclipse.org/technology/mat/0.8/update-site/. However,
after installing this plugin, I do not see any menu or option in eclipse
to open or analyse heap dumps. Am I missing something ? Anything extra
also needs to be installed ?
Re: Setting up MAT with eclipse [message #11259 is a reply to message #11227] Wed, 15 July 2009 13:03 Go to previous messageGo to next message
Andreas Buchen is currently offline Andreas Buchen
These are some ways to start:
(i) Select File -> Open File... and select a .hprof file
(ii) Select Window -> Open Perspective... -> Memory Analyzer. Then you
have an additional menu entry "Open heap dump" with the proper extension
filters. You also see the object inspector etc.
If you are wondering if the installation of MAT was successful, check the
plugin details of the About dialog for org.eclipse.mat.* plugins.
Re: Setting up MAT with eclipse [message #11296 is a reply to message #11259] Fri, 17 July 2009 06:04 Go to previous message
Thanks for the prompt response, Andreas.
Previous Topic:DTFJ queries
Next Topic:Could not parse big heap file
Current Time: Thu May 23 08:58:58 EDT 2013
Powered by FUDForum. Page generated in 0.01850 seconds
