Home » Eclipse Projects » EPP » Usage of UDC in 3rd party Eclipse plugins and distributions
Usage of UDC in 3rd party Eclipse plugins and distributions [message #11207] Thu, 07 May 2009 04:57 Go to next message
Eclipse User
Originally posted by: max.andersen.redhat.com
I'm looking into how best to use UDC from our plugins (JBoss Tools) and
our distribution (JBoss Developer Studio) and I bumped into some
challenges :)
1) Where is the server side part of UDC ? I can only find the client
side code.
2) Can UDC upload the collected data based on what plugins the usage is
for ? (since I don't want to mess with users default UDC upload location
when I'm "just" a 3rd party installed plugin)
3) Or alternatively can 3rd party *plugins* get access to the data
collected by Eclipse.org ?
4) Has UDC exposed some public API's for Galileo ?
/max
Re: Usage of UDC in 3rd party Eclipse plugins and distributions [message #11240 is a reply to message #11207] Thu, 07 May 2009 08:34 Go to previous messageGo to next message
Eclipse User
Originally posted by: jacek.pospychala.pl.ibm.com
Hi Max,
while am not UDC dev, I have looked at it too and have some similar
concerns.
Max Rydahl Andersen pisze:
> side code.
I have not found that in WWW cvs, or technology cvs repo.
However it's fairly easy to create your own - just expose a page that
logs somehow the HTTP POST requests.
Not really. It's fairly simple to redirect UDC to upload data to a
different host. And IMHO it's reasonable to do so in your own product
(JBoss Developer Studio case), however you may need to update some of
the privacy statements accordingly.
what do you want to achieve here?
UDC has no APIs.
Re: Usage of UDC in 3rd party Eclipse plugins and distributions [message #11275 is a reply to message #11240] Thu, 07 May 2009 16:58 Go to previous messageGo to next message
Eclipse User
>> side code.
Okey - I guess I just have to "reverse engineer" it.
>> is for ? (since I don't want to mess with users default UDC upload
>> location when I'm "just" a 3rd party installed plugin)
hmm - I would like to avoid having to change "base eclipse plugins" but
I guess I can be forced to.
JBoss Tools plugins has about 30 to 50k downloads a month from our
update and download site which means there is *alot* of users which
runs the plugins on a base eclipse - which I can't get the stats for.
but eclipse.org have them.
I would like to see more than just *** in the reports ;)
> UDC has no APIs.
bummer.
/max
Re: Usage of UDC in 3rd party Eclipse plugins and distributions [message #11312 is a reply to message #11275] Fri, 08 May 2009 05:30 Go to previous messageGo to next message
Eclipse User
>>> side code.
The simplest approach for me was a servlet with doPost() method looking
like:
HttpServletRequest req = ...
ServletFileUpload upload = new ServletFileUpload(new DiskFileItemFactory());
List items = upload.parseRequest(req);
for (Iterator i = items.iterator(); i.hasNext(); ) {
FileItem item = (FileItem) i.next();
System.out.println(item.getFileName()+" = "+item.getString());
using Apache commons fileupload. You get CSV files, with header in first
line followed by rows of comma-separated data.
Anyway, it'd be good if UDC project had provided some, even simple, server.
Woudln't that violate the UDC Terms of Use? (It says only Foundation is
collecting that data). Technically that should be doable, however a bit
hackish - accessing other plug-in files
(workspace\.metadata\.plugins\org.eclipse.epp.usagedata.reco rding\*).
Have you tried contact Foundation directly to get more detailed report?
Re: Usage of UDC in 3rd party Eclipse plugins and distributions [message #11348 is a reply to message #11312] Sun, 10 May 2009 06:11 Go to previous messageGo to next message
Eclipse User
>>>> side code.
> like:
thanks!
Yes, it probably woul.
Yes, and the answer have been that "We are looking into it.." - which is
now over a year ago I believe. Hence why i'm trying to start collecting
the items on my own.
/max
Re: Usage of UDC in 3rd party Eclipse plugins and distributions [message #11532 is a reply to message #11348] Mon, 15 June 2009 06:40 Go to previous message
Eclipse User
Hi Max,
still interested in UDC?
I'm also trying to get some more reports from foundation/EPP, but with
no response so far. Have a look at bug "More reports from UDC" -
https://bugs.eclipse.org/bugs/show_bug.cgi?id=279210
Re: Usage of UDC in 3rd party Eclipse plugins and distributions [message #578683 is a reply to message #11207] Thu, 07 May 2009 08:34 Go to previous message
Jacek Pospychala is currently offline Jacek Pospychala
Hi Max,
concerns.
> side code.
UDC has no APIs.
Re: Usage of UDC in 3rd party Eclipse plugins and distributions [message #578752 is a reply to message #11240] Thu, 07 May 2009 16:58 Go to previous message
Max Rydahl Andersen is currently offline Max Rydahl Andersen
>> side code.
> UDC has no APIs.
bummer.
/max
Re: Usage of UDC in 3rd party Eclipse plugins and distributions [message #578813 is a reply to message #11275] Fri, 08 May 2009 05:30 Go to previous message
>>> side code.
like:
Re: Usage of UDC in 3rd party Eclipse plugins and distributions [message #578871 is a reply to message #11312] Sun, 10 May 2009 06:11 Go to previous message
>>>> side code.
> like:
thanks!
/max
Re: Usage of UDC in 3rd party Eclipse plugins and distributions [message #579027 is a reply to message #11348] Mon, 15 June 2009 06:40 Go to previous message
Hi Max,
Previous Topic:Downloading an update site to a local mirror programmatically
Next Topic:Galileo Packages Cocoa 64 Bit
Current Time: Sun May 19 16:43:18 EDT 2013
Powered by FUDForum. Page generated in 0.02336 seconds
