Home » Eclipse Projects » e(fx)clipse » E4 part with JavaFX
E4 part with JavaFX [message #1095290] Mon, 26 August 2013 22:18 Go to next message
Dirk Fauth is currently offline Dirk FauthFriend
I just started creating an E4 application using JavaFX. Of course I'm using e(fx)clipse! Wink
Looking at the short tutorials and the sample application I noticed that I can get the BorderPane injected in @PostConstruct. But where is configured which pane should be used? When I tried to get a StackPane, an exception was thrown that there is no value found for a StackPane.
So the question in detail, as the DI concepts are hopefully quite clear to me, which panes are supported? Am I able to change which pane to use as root pane? And if so, where to configure it?
Thanks for helping a newcomer to e(fx)clipse! Smile
Greez,
Dirk
Re: E4 part with JavaFX [message #1096079 is a reply to message #1095290] Tue, 27 August 2013 23:46 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
we always inject a BorderPane because it is the most natural and often
used one. You can not tell the system that you want another pane but
have to position your stuff on the BorderPane.
Tom
On 27.08.13 00:18, Dirk Fauth wrote:
> using e(fx)clipse! ;)
> Thanks for helping a newcomer to e(fx)clipse! :)
> Greez,
> Dirk
Re: E4 part with JavaFX [message #1096560 is a reply to message #1096079] Wed, 28 August 2013 15:10 Go to previous messageGo to next message
Thanks for the answer. IMHO it should be possible for users to select the pane they want to use. Even if the BorderPane is a good default, people might want to use a different one.
Maybe this can be done by setting a tag to the part? What do you think?
Greez,
Dirk
Re: E4 part with JavaFX [message #1096612 is a reply to message #1096560] Wed, 28 August 2013 16:26 Go to previous messageGo to next message
File a Bugzilla, generally speaking I think forcing the user to e.g.
create a StackPane is acceptable but you are right, file a bugzilla and
we can add a tag.
Tom
On 28.08.13 17:10, Dirk Fauth wrote:
> Greez, Dirk
Re: E4 part with JavaFX [message #1098604 is a reply to message #1096612] Sat, 31 August 2013 10:35 Go to previous messageGo to next message
Ticket created: https://bugs.eclipse.org/bugs/show_bug.cgi?id=416288
Re: E4 part with JavaFX [message #1128277 is a reply to message #1098604] Mon, 07 October 2013 14:30 Go to previous messageGo to next message
Ghislain Mustermann is currently offline Ghislain MustermannFriend
Well when im trying to use AnchorPane or FillLayoutPane it dont work i have an Error : Quote:
org.eclipse.e4.core.di.InjectionException: Unable to process "LoginScreenPart#init()": no actual value was found for the argument "FillLayoutPane".
What im doing wrong? although i added "org.eclipse.fx.ui.panes (0.9.0)" to my required plug ins.
Re: E4 part with JavaFX [message #1128289 is a reply to message #1128277] Mon, 07 October 2013 14:42 Go to previous message
So did you use the tag to inform the renderer that it should create a
FillLayoutPane?
See the list of tags at http://wiki.eclipse.org/Efxclipse/Runtime/e4#MPart
Tom
>> "FillLayoutPane".
Re: E4 part with JavaFX [message #1742016 is a reply to message #1095290] Tue, 27 August 2013 23:46 Go to previous message
Tom
> Greez,
> Dirk
Previous Topic:Missing OSGi-Bundle Dependencies
Next Topic:FXGraph and Preview no longer in sync
Current Time: Sat Jul 22 09:22:17 GMT 2017
Powered by FUDForum. Page generated in 0.06743 seconds
