Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » [AGR] Unsuccessful recording on Linux
[AGR] Unsuccessful recording on Linux [message #108531] Sat, 11 August 2007 11:29 Go to next message
Barbara Rosi-Schwartz is currently offline Barbara Rosi-Schwartz
Hello everybody.
I am attempting to record a very simple test under Linux, but without
success.
All I am trying to do is to start a test in the Resource perspective and
create a simple project. The New wizard comes up but acts, to all
intents and purposes, as if it was frozen. I cannot use the scroller in
the dialog, nor can I open/close/select/double click on any element in
the dialog's tree.
I am using RHEL 5 on a 64 bit machine with TPTP/AGR 4.4.0 and the
integrated Agent Controller. From looking at the documentation at
http://www.eclipse.org/tptp/home/project_info/releaseinfo/4. 4/support.html#Workbench,
I know this is not one of the configurations on which you currently have
successful tests, but I am wondering if anybody could provide a pointer
to a possible way forward with this.
TIA,
B.
Re: [AGR] Unsuccessful recording on Linux [message #108747 is a reply to message #108531] Mon, 13 August 2007 08:04 Go to previous messageGo to next message
Paul Slauenwhite is currently offline Paul Slauenwhite
Hi Barbara,
This type of recording is a standard test we execute during each test
pass on both Windows and Linux
( http://www.eclipse.org/tptp/home/project_info/releaseinfo/4. 4/support.html).
As such, this may be related to newer OS version or 64 architecture.
Unfortunately, we do not have pointers to resolve this symptom. Please open
a bugzilla against the TPTP Testing product and Test.UI.AutoGUIUI component.
However, we will not be able to have this fixed until 4.5.
Paul
"Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
news:f9kkkj$v3q$1@build.eclipse.org...
> Hello everybody.
> success.
> create a simple project. The New wizard comes up but acts, to all intents
> and purposes, as if it was frozen. I cannot use the scroller in the
> dialog, nor can I open/close/select/double click on any element in the
> dialog's tree.
> successful tests, but I am wondering if anybody could provide a pointer to
> TIA,
> B.
Re: [AGR] Unsuccessful recording on Linux [message #108824 is a reply to message #108747] Mon, 13 August 2007 10:47 Go to previous message
Created issue 199756.
B.
Paul Slauenwhite wrote:
> Hi Barbara,
> Paul
Previous Topic:Irreproducible output when manually creating test results reports
Next Topic:AGR 4.3 -> AGR 4.4
Current Time: Wed May 22 04:46:55 EDT 2013
Powered by FUDForum. Page generated in 0.02672 seconds
